I would like to pick the brains of the forum
All  1  2-3
9027.2 In reply to 9027.1
Hi Peter,
I would probably use the flow deformation tool to twist a 'flat' leave, so you can first work on the global silhouette.
A : I loft 3 lines to create the rest position surface
B : you can then create multiple targets shape, by editing the shape, or rotate the lines and take advantage of the construction history
C : build the "flat" leave, here I'm using a sweep by 2 rails, but they are probably lots of other way.
D : finally use the deform/flow , the sequence is something like picking the leaves, activate the flow command, picking the rest surface, picking the target surface. You need to practice a little to see how the tool works.
9027.3 In reply to 9027.2
Thank you I will give that a try!
Show messages: All  1  2-3
