Problem with 3DConnexion SpaceNavigator in MoI
All  1-3  4-7
9024.4
Hello Michael,
>Does it behave odd with just one particular model?
No, unfortunately not. Actually, I've got two 3D mice, one SpaceMouse Wireless and one SpaceMouse Enterprise (of course on different PCs, haha), but I tested both with MoI, and the behavior is the same.
>What happens if you use it on a totally blank MoI that you just start up?
No difference.
>You also might try the option under Options > "Rotate/Pan/Zoom options" > "Rotation style" (at the top of the dialog). Try setting Rotation style: Free rotation and see if that is better for you.
Not much better. Thing is, I work with both my 3D mouse and keyboard shortcuts to control the camera. I like "free rotation" more for work with my 3D mouse, and "rotate around z world axis" for when I navigate with keyboard shortcuts. Sadly, this setting is only global. Michael, maybe you can add a certain rotation style setting to 3D mouse setting for final v4?
These are my current settings (free rotation):
MoI:
3Dc driver:
These are my current settings (rotate around z world axis):
MoI:
3Dc driver:
Better than before, but all in all it still feels kinda quirky and not so much natural as in e. g. Fusion 360.
As always, thanks for your help, Michael.
9024.5 In reply to 9024.4
Hi 3image, sorry it's not working well for you. Unfortunately that's a kind of unusual method you're using with combining keyboard shortcuts in some instances and SpaceMouse in other instances. I think it could get kind of complicated to have individual settings rather than a global setting for the navigation behavior so I'm sorry it's not likely to happen for v4.
Did you also experiment with setting the 3D view projection to parallel to see if that helps any?
9024.6 In reply to 9024.5
Unfortunately, it didn't help that much. Anyways, I like the parallel projection in MoI, that's why it's my new standard projection now. :-)
I'm curious. Is there a reason, why we have to work with a start-up file to change the projection to parallel permanently?
9024.7 In reply to 9024.6
Hi 3image,
It's because that is something stored and read from 3dm model files, it's not a global setting.
Show messages: All  1-3  4-7
