stl Export for 3d printing
All  1  2-5
9020.2 In reply to 9020.1
Hi Ben, the .stl format does not have any method for containing multiple objects, it's only really intended to contain a single object and it only has a place in the file for storing a single object name. So the "merge object with the same name" doesn't have any effect on STL exports.
You can probably get away with putting multiple objects in one single stl file if they don't touch each other, but when they are touching it's difficult for the program that is receiving the file to be able to tell them apart.
You may have to export each object to its own separate .stl file, or possibly use a different format like obj format which does support having multiple labeled objects in a single file.
It's hard to say for sure what you should do because it's dependent on the particular slicing software and capabilities of your printer.
9020.3 In reply to 9020.1
Hi noskule,
i dont know if this helps but have a look here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8965.3&highlight=yes
Ralf:)
looking for moments of inspiration...
Hi Ben,
i don't know if your printer supports VRML (.wrl files), if so, i use this format all
the time via Blender, to have seperated objects with colors, or single objects
with assigned stile colors from MoI, on individual faces. I simply export as .obj
from MoI and in Blender i save as .wrl.
9020.5
OK, I figured out the way to do it is just export each part as separate stl file. Then import it into slicer software and mege them to an "objectgroup". The parts will then allign to each others original relativ position.
Thanks Ben
Show messages: All  1  2-5
