Pattern on a Sphere
 1-6  7-26  27-46  47-66  67-86  87-106  …  167-184
9014.47 In reply to 9014.45
Hi Stefan,
A slightly different approach.
I trimmed a sphere with triangle shapes, then ran transform-deform-twist on the resulting surface. Put a small explodemove on just the trimmed pieces after the twist.
Hi BurrMan,
very good idea and looking cool! Now i would copy and paste the edges from the surfaces
and then construct "cutting objects"*, to slice another sphere, to get your nice pattern on
a solid sphere... :-)
I usually create those with duplicating the curves and scale one inwards a sphere and
the other one outside the sphere and loft them, to use the lofted surfaces as trim objects
for a solid sphere.
[EDIT]
Why do i create lofted "cutting surfaces" instead of projecting and then trimming? Because
i often have holes here and there in the solid surface when using complicated patterns.
With "cutting surfaces" i don't have this issue. ;-)
EDITED: 27 Jul 2018 by STEFAN
9014.49 In reply to 9014.48
Hi Stefan,
The object and result was a solid sphere!
I just unjoined and explodemoved it for the visual effect.
So, dice some fundamental pattern on a sphere surface, then "twist" it to get some of those more "Organic shapes"...
The sphere wont deform in a twist on its center axis.
9014.50 In reply to 9014.49
Before a twist....
Hi BurrMan,
Ah o.k.! I only thought when "re-projecting" your nice surfaces you would have than more
space between each surface.
[EDIT] Never mind, i am probably wrong with my thinking and have to try it out myself.
Hello :)
...blobs, blobs, blobs! :)
(Moi + Thea Render + Affinity Photo)
...as usual...no uv, no retopo, no texturing.
Ciao!
Hello everyone!
...stars on ball!
(Moi + Thea Render)
Ciao!
9014.54
Hi Stefan and Friends ,
It seems that I find it taste .....
Another Pattern (PhylloPattern on Sphere) with multiple outputs,
(see attached images) some concerning the Form and the Volumes,
Others , more the graphic appearance (Colors) .
I hope it is a your liking and maybe a suggestion for as many futures
contaminations ......
Files and images to this link:
http://www.mediafire.com/file/5cykyb2jo0s8lx6/PhylloPatternonSphere.zip/file
If you believe that the topic is interesting, kindly publish it....
Thank you for the great patience you show with me.
Have a nice evening
al
9014.55 In reply to 9014.54
Hello AL!
Wonderful pattern!!
But...why don't you directly include the final images into the messages that you post?
It's really a pity to be forced to download the zip, extract, then view the images...
Your stuff deserve to be viewed instantly :)
9014.56
Marco, Stefan , and friends, if you do not place my files directly
and related images, it is simply because not
I can no longer do it, as I said,
I do not know if it depends on the Server or what else ...
the fact is that after the seismic events that occurred
in the Marche (Italy), where I live, I could not do it anymore
Sorry, but this is the reality ......
I hope in the future that I can normally post my work
Sorry again , and
Have a nice day to all
al
9014.57 In reply to 9014.56
Ciao AL!
(Italian)
...ma che strano problema questo dell'update impedito per le foto...stranissimo.
Mai sentita una cosa del genere.
Evidentemente come dici te e successo qualche casino grosso a livello di Server della telefonia...
Spero che presto le cose si mettano a posto :)
English.
Hello AL!
OK. Got it. I hope that soon your internet connection will be restored to its usual behavior.
Ciao!
Message 9014.58 deleted 2 Feb 2024 by JFH
9014.59 In reply to 9014.58
Delicious!
Hello everyone!
...not strictly "on sphere" but..."on disc" :)
Moi + 3D-Coat + Affinity Photo (Back image from Pexel)
Ciao!
Message 9014.61 deleted 2 Feb 2024 by JFH
9014.62 In reply to 9014.61
Beatiful!!
Hi all,
i am currently busy with non-related 3D things and therefore have no time
to visit the forum daily.
Nice submissions from you all. Keep up the good work!
9014.64 In reply to 9014.63
Thanks Stefan!
Have a nice day!
9014.65
Hi Friends
Anyone interested can find this link :
http://www.mediafire.com/file/kajf8j19alp8383/TriaPatternonSphere.zip/file
file.nod and picture of
Triangular Pattern on Sphere, in the file I used
my last Macro _Exp Polyhedron
have a nice day to all
al
Ps- Note that the Boolean are really
stable, slow, sometimes very slow, but
they give great results,
notice the quality of the single cut surface
Message 9014.66 deleted 2 Feb 2024 by JFH
Show messages:  1-6  7-26  27-46  47-66  67-86  87-106  107-126  …  167-184
