Pattern on a Sphere
 1-19  20-39  40-59  60-79  80-99  …  180-184
9014.40 In reply to 9014.39
Very nice jobs here !
...and a quick rendering of my loxodrome sphere.
screenshot001
@Marco the CGSphere Project runs since 2006 and artist from all over the world
have there submitted their sphere models. Quite superb things one could see there.
P.S. i submitted there a couple of years ago the template file for Shade3D. There
are many templates files available for a lot of DCC apps.
O.k. ... and a quick rendering from the tiled birds.
screenshot003
9014.44 In reply to 9014.43
Tessellation on sphere in MoI is really masterpiece.
Mik
Hi Mik,
it is possible due to MoI's super easy to use and logical UI and toolset.
I, for example, could not do such things with other NURBS modelers i
have tried in the past. The only thing i must get more comfortable with
is the orient and flow tools. If i could master them, then i would try
more birds on a sphere, instead of eight... ;-)
9014.46 In reply to 9014.45
Hi Stefan,
you are right MoI is super and flow, orient or curve projected tool is very powerful for working with curved surfaces including sphere.
Ciao
Mik
9014.47 In reply to 9014.45
Hi Stefan,
A slightly different approach.
I trimmed a sphere with triangle shapes, then ran transform-deform-twist on the resulting surface. Put a small explodemove on just the trimmed pieces after the twist.
Hi BurrMan,
very good idea and looking cool! Now i would copy and paste the edges from the surfaces
and then construct "cutting objects"*, to slice another sphere, to get your nice pattern on
a solid sphere... :-)
I usually create those with duplicating the curves and scale one inwards a sphere and
the other one outside the sphere and loft them, to use the lofted surfaces as trim objects
for a solid sphere.
[EDIT]
Why do i create lofted "cutting surfaces" instead of projecting and then trimming? Because
i often have holes here and there in the solid surface when using complicated patterns.
With "cutting surfaces" i don't have this issue. ;-)
EDITED: 27 Jul 2018 by STEFAN
9014.49 In reply to 9014.48
Hi Stefan,
The object and result was a solid sphere!
I just unjoined and explodemoved it for the visual effect.
So, dice some fundamental pattern on a sphere surface, then "twist" it to get some of those more "Organic shapes"...
The sphere wont deform in a twist on its center axis.
9014.50 In reply to 9014.49
Before a twist....
Hi BurrMan,
Ah o.k.! I only thought when "re-projecting" your nice surfaces you would have than more
space between each surface.
[EDIT] Never mind, i am probably wrong with my thinking and have to try it out myself.
Hello :)
...blobs, blobs, blobs! :)
(Moi + Thea Render + Affinity Photo)
...as usual...no uv, no retopo, no texturing.
Ciao!
Hello everyone!
...stars on ball!
(Moi + Thea Render)
Ciao!
9014.54
Hi Stefan and Friends ,
It seems that I find it taste .....
Another Pattern (PhylloPattern on Sphere) with multiple outputs,
(see attached images) some concerning the Form and the Volumes,
Others , more the graphic appearance (Colors) .
I hope it is a your liking and maybe a suggestion for as many futures
contaminations ......
Files and images to this link:
http://www.mediafire.com/file/5cykyb2jo0s8lx6/PhylloPatternonSphere.zip/file
If you believe that the topic is interesting, kindly publish it....
Thank you for the great patience you show with me.
Have a nice evening
al
9014.55 In reply to 9014.54
Hello AL!
Wonderful pattern!!
But...why don't you directly include the final images into the messages that you post?
It's really a pity to be forced to download the zip, extract, then view the images...
Your stuff deserve to be viewed instantly :)
9014.56
Marco, Stefan , and friends, if you do not place my files directly
and related images, it is simply because not
I can no longer do it, as I said,
I do not know if it depends on the Server or what else ...
the fact is that after the seismic events that occurred
in the Marche (Italy), where I live, I could not do it anymore
Sorry, but this is the reality ......
I hope in the future that I can normally post my work
Sorry again , and
Have a nice day to all
al
9014.57 In reply to 9014.56
Ciao AL!
(Italian)
...ma che strano problema questo dell'update impedito per le foto...stranissimo.
Mai sentita una cosa del genere.
Evidentemente come dici te e successo qualche casino grosso a livello di Server della telefonia...
Spero che presto le cose si mettano a posto :)
English.
Hello AL!
OK. Got it. I hope that soon your internet connection will be restored to its usual behavior.
Ciao!
Message 9014.58 deleted 2 Feb 2024 by JFH
9014.59 In reply to 9014.58
Delicious!
Show messages:  1-19  20-39  40-59  60-79  80-99  100-119  …  180-184
