Fillet question
All  1-4  5-9
while i can't help with your question i would take a look at free (for non-commercial usage)
solutions like Autodesk 123D Design etc, which can fillet the edges.
Bildschirmfoto_2018-07-15_um_14.09.22
bild hochladen url
With your actual curves you can make something like that
Select a line of curves / Join
Select all joined Curves / Loft
Close head curve with a line then Loft
So no need fillet! :)
But better to build longitudinal lines as curves and not polylines!
Here redraw the curves free form "through" your points then Loft
EDITED: 15 Jul 2018 by PILOU
9007.7 In reply to 9007.6
Ace! Thanks for your help Pilou.
9007.8 In reply to 9007.4
Hi Dan, check out here for some tips for people coming from a poly modeling background:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
The strategies you use in NURBS modeling are pretty different than what you do in poly modeling.
9007.9 In reply to 9007.8
Thanks Michael,
I am starting to get my head around it. After a fair amount of tutorials and forum threads it all starts making sense :)
Dan
Show messages: All  1-4  5-9
