need to click and drag joined lines?
All  1  2
9003.2 In reply to 9003.1
Hi Supagoat, that's a feature that is enabled when edit points are turned on:
http://moi3d.com/3.0/docs/moi_command_reference4.htm#showpoints
quote:
When a curve has control points turned on, an additional edit mode is enabled if you click and drag on the body of an unselected curve. This enables "drag point on curve" mode where the curve will be deformed to pass through the point you dragged on. This works by moving several nearby control points in one single action, so it can be useful for roughing out the shape of the curve.
If you turn off edit points (click Edit > Show pts again or push Esc) then it should drag in one action like you're used to.
Show messages: All  1  2
