MoI3D to CNC router ...
All  1-13  14-16
8998.14 In reply to 8998.13
Hi Wimverbe,
First - thank you very much for your prompt reply! ... I appreciate this ;-)
And then - seeing the screendumps in your post I looked a bit more into this this morning and found out that the reason why I can't export DXF from within MoI is because I am using V2. Apparently DXF export was added to MoI in V3. And for some reason the other solutions I tried for converting the file to DXF (online internet conversion & other CAD programs) didn't work at least from a quick glance ...
This is to say that since I have for a long time now been considering upgrading to V3 I decided that this was the time to do so. Thus I have now bought an upgrade and with inspiration from your guidance it took less than five minutes to make the DXF export and correctly import it into Estlcam. Quite a relief ..
So Wimverbe - thanks again for your help & wishing you a pleasant day ;-)
Jesper
8998.15 In reply to 8998.14
glad it works for you Yesper!
happy milling!
wim
8998.16 In reply to 8998.14
Upgrading good! You are good to go....
For anybody else, michael wrote a helper program for those older versions... it's towards the bottom of the resources page.
3dm curves to dxf....
Show messages: All  1-13  14-16
