A free render for Moi
All  1-20
SimLab Composer 9 is released!
The free version is Real Time or not (Maxi 1920 *1080)
You can use it for commercial use!
OBJ or any 3D format like SKP is permited! (for Moi you can use Nurbs formats but not 3DM! )
Animation is not for the free version!
My Moi French Site My Gallery
8994.2
Give the [Armory](https://armory3d.org) a try.
And don't forget to check the upcoming Blender 2.8 which seems to be quite good at realtime rendering.
[Blender Eevee Test: Interior Scene 2](https://youtu.be/ZlCVAxFvWPQ)
In the easy 3D Virtual Reality world (works also with a Mouse ;) take a look to
the Free PBR* for free SKetchUP Make 2017 (or Pro) ! Moi exports in SKP file format! ;)
(speedy zooms are insane! :)
By a French guy Samuel
http://moiscript.weebly.com/pbr.html (in French ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.296 (in English ;)
*Physical Based Render
(not sure that the device following is free price also! :)
EDITED: 21 Jul 2018 by PILOU
8994.4 In reply to 8994.2
Are you serious about it? is a game engine, although it can be used for rendering, it is not the most suitable for Moi3d users. . it is a Blender fork and the programmer now works for the new version of Blender2.8..And learning how to use the Real-time Rendering engine takes time. The best way is always to use Cycles or wait for the month of October where the new version of Blender will most likely be available.
Another one similar to TwinMotion!
D5 Render!
https://www.d5render.com/
EDITED: 30 Mar 2023 by PILOU
Not really a render but! :)
New Alpaca online
https://www.alpacaml.com
so with the free SketchUp online! :)
Same sketch than above but with Vizcom...
Test of Alpaca with moi Objects
EDITED: 5 Jul 2024 by PILOU
https://websim.ai/ free
For make a site with ai in 5 seconds! :shock:
And you can make anything !!! :shock: :shock: :shock:
So the result with "island inside tempest"
Works fine but very slow! :roll:
EDITED: 25 Jun 2025 by PILOU
Free Vizcom
A true real time renderer for moi!
The KREA interface has changed but the “Real time rendering” function is still there (even in free)
Of course, you can use any program as a source! Even Krea itself, for make a meta AI, doesn't even larsen effect!
My Moi French Site
Another new thing for apply some textures on an image of any volume!
And it's free! https://aistudio.google.com/prompts/new_chat
So any moi volume
will be texturized in 10 - 20 seconds
Can be rotated but in 200 seconds
so better rotate inside Moi / Snapshot and apply a texture!
And make also without effort some other little things!
(moto is free Daz ai)
etc...
have fun!
EDITED: 1 Sep 2025 by PILOU
8994.16
Simlab composer confuses me..
I was about to get blender Ducky3d materials...but found out a few days ago that Plasticity has materials as well.
works good for what I need simple and fast. I still think Lightracer is a good price.
8994.17 In reply to 8994.16
Free Simslab render is an very easy traditional render... ;)
But today you can use also this sort of thing! ;)
Free Krea Real Time Screen!
Put any prog on the left Moi3D if it's your favorite 3D prog...
Here double sessions of free Krea Real Time Screen for an infinite Ping Pong creative result!
A sort of double temporal loop creative! :)
With moi 3D in Real time! ;)
Just write a "material prompt" and play with the Strength Slider creativity!
Remark the third wheel, normal it's a concept car! :)
EDITED: 16 Sep 2025 by PILOU
Vizcom in free can be a cool render and modifier for MOi!
Vizcom allows for free exports at 1K, 2K, 4K, and 8K resolutions but not using the Mix function! (just click the image! ;)
Simply click on the image, select the Download icon, and choose "Export"... the processing time will depend on the format!
https://moiscript.weebly.com/vizcom.html
Render can be made in 1k, 2K, 4 K but can be also re calculated at export in 8k !
Even in SVG !!!
That we can of course reload in Moi! :)
EDITED: 11 Sep by PILOU
You can make 3D from the Image for use it as you want on your Vizcom screen!!!
But not yet sure that you can export the 3D file in free version! :) (i verifiy) No you can't!
But you can use all the other functions! :)
My Moi French Site
Show messages: All  1-20
