Moi3d vs Rhino
All  1-4  5-14
8993.5 In reply to 8993.1
""""""""""Does anyone design with the two programs? Do they complement each other?""""""""""
Bingo!
You can work with MoI, then use Rhino when you need more advanced operations with things like Patch modeling/Surface continuity matching etc.....
8993.6 In reply to 8993.1
Hi Kisar, there are a lot of people who use MoI and Rhino in combination with each other. The strong areas of MoI are in the basic stuff like drawing, snapping and selection functions.
MoI uses the Solids++ kernel. I'd recommend testing out the trial version to see if you like it.
8993.7
I do architectural work. I love designing and modeling with MoI3d. I do use it in tandem with Rhino. Rhino currently has features that MoI does not ... dimensioning is a prime example. It is coming to MoI in the relatively near future. Rhino reads MoI files perfectly so switching to add dimensions and other features is easy. I do currently need both programs. I usually do as much as I can with MoI and then switch to Rhino for more finished work.
cheers,
eric
8993.8 In reply to 8993.7
Hi Michael ...
Dimensions soon in Beta 4 ?
cheers,
eric
8993.9 In reply to 8993.8
Hi eric, sorry probably not for the next beta but probably the one after. It will probably be one of the last areas that I'll work on before wrapping up v4.
8993.10 In reply to 8993.9
Thanks for the reply Michael.
I'll just keep anticipating.
cheers,
eric
8993.11 In reply to 8993.3
Rhino 6 now incorporates a new render engine which is "borrowed" from Blender. It's the Cycles Renderer which can produce really astounding results, even in real time mode. You should give it a try.
8993.12 In reply to 8993.11
Hello 3image.
I'm sorry but I have to disagree.
The current Rhino's implementation of Cycles it's absolutely not comparable with the counterpart that we have in Blender.
I can say this because I have both Rhino V5 for some years and I've tested for several months the version V6 WIP (all the latest builds) of Rhino.
The implementation of Cycles in Rhino it's "only a shadow" compared to the full and very powerful Cycles engine that you have in Blender.
Regards.
8993.13 In reply to 8993.12
Hello Marco,
Yes, I know, it's indeed not comparable to Blender. Especially not with Blender 2.8 on the horizon.
What I meant was that the new renderer in Rhino v6 is way better compared to the old native renderer of Rhino v5. And I think this is very true.
8993.14 In reply to 8993.13
Hi 3image.
@You : "...the new renderer in Rhino v6 is way better compared to the old native renderer of Rhino v5..."
Oh..yes! About this point I agree with you.
It's built-in the Rhino package and this is good, considering how much Rhino costs.
But, beside the overall quality and feature that are much less then the counterpart in Blender, it's also rather slower than it.
Anyway...it's included into the Rhino package and it's better than nothing :)
Ciao :)
Show messages: All  1-4  5-14
