coordinates of a point
All  1-4  5-9
8987.5
Thank you so much guys
a last question how do you use the scripts? ..... what is the procedure to use them?
with keyboard shortcuts or something else?
8987.6 In reply to 8987.5
Ok I understand .... thanks again :)
8987.7 In reply to 8987.6
Hi guys
sorry for the trouble but I have a problem, exceeded that of the coordinates of the points I need to measure the angles of the triangle that has the vertices with various heights in Z as you can see from the figure.
If I project on the plane C the figure can safely but I have noticed that I lose obviously the proportion of the triangle.
how can I measure the angles of the triangle with the vertices with the values of the different vertices?
Size: 152.2 KB, Downloaded: 34 times, Dimensions: 1175x758px
8987.8 In reply to 8987.7
8987.9 In reply to 8987.7
Hi!
Now I've tried - also a possibility:
Max Smirnov's script "PointsOnCurve" still has a nice function to get coordinates of points,
and angles with script _Dimensions (Max).
http://moi3d.com/forum/index.php?webtag=MOI&msg=7403.1
Franz
EDITED: 30 Jun 2018 by FRANZ
Size: 93.1 KB, Downloaded: 44 times, Dimensions: 802x500px
Size: 71.5 KB, Downloaded: 42 times, Dimensions: 586x600px
Show messages: All  1-4  5-9
