Problem with exporting from MOI 4.0 to Adobe Illustrator
All  1  2-4
8980.2 In reply to 8980.1
Hi Petr, are you using the "Preserve Units" option when you're exporting? If so then it's possible that your objects are some distance away from the visible page in Illustrator. With "Preserve Units" enabled, currently MoI will map its 0,0,0 world origin point to the 0,0 Illustrator origin which is in the lower left corner of the page in AI. So you would want to make sure your objects are contained within a page sized rectangle area starting at 0,0,0 in MoI if you're using that option.
If that's not what you were running into can you please post your AI file here or send it to me at moi@moi3d.com through e-mail if you want to keep it private?
8980.3 In reply to 8980.2
Thank you for getting back so quick and apologies for late reply, have been away. I'll have a look at come back to you.
Petr
8980.4 In reply to 8980.3
Yes, it was off the grid and so wasn't working. In other software the thing you have highlighted becomes the area of focus for the export and it was this that threw me. That and not having the grid visible.
Thanks again for the help!
Best
Petr
Show messages: All  1  2-4
