To handle Sub Divisions
All  1  2-7
8973.2 In reply to 8973.1
You must have generally "Quads" faces of the object for make SUbdivisions
or no more 5 polygons !
So make first this sort of face subDivision
Or more generally you can use sSplit, sBridge, sScale By Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
(in this object Top / Bottom faces will not subdivided - too much polygons)
Here use sSplit (don't select object but FACES-edge !!! )
Use only SBridge for create the "Bridge(s)" face to face (make them manually will not works for the SubDivision)
and then use SubDivision :)
EDITED: 14 Jun 2018 by PILOU
8973.3 In reply to 8973.1
Hi Raymond, yes like Pilou says the problem you've got there is you have many faces that have more than 4 edges. A sub-d model needs to have things divided up into smaller elements than that, it has to be made up of quad polygons not like your structure.
A model like you show there with lots of planar areas is better to do in NURBS than in sub-d anyway, just select what you've already built and run the Construct > Fillet command to smooth off its edges rather than trying to do sub-d on it:
i gave the shape a quick try, so that you can see how the faces should look
like, in order to use Max's subd script. Depending of what look you are after
you may have to add some edge loops, so that the shape looks more like
Michael's example.
Hope this helps.
Bildschirmfoto_2018-06-14_um_14.52.07
picture hosting
8973.5 In reply to 8973.4
I don't have words to say, Thank you for your professional way that I so in you all there.
With your help I manage to use these amaze commands and hope that Michael incorporate them to the new V4.
Make an area for them because it's nice to have them.
Thanks again for your effort to everyone there.
Regards,
Raymond
8973.6 In reply to 8973.5
Hi all,
With your help provided, I made this so far and I am very happy that I done it.
thanks again,
Raymond
Size: 331.5 KB, Downloaded: 102 times, Dimensions: 1920x1042px
Cuty beginnings!
My Moi French Site My Gallery
Show messages: All  1  2-7
