V4 beta Jun-6-2018 available now
 1-2  3-22  23-42  43-62  63-68
8966.23 In reply to 8966.19
I have adjusted the grip frames size in the Moi.ini file and much better visibility.
Many thanks
Barry
I increased EditFrameGripPixelSize to 32. Much easier to find the frame handles on my widescreen monitor - Thanks!
8966.25 In reply to 8966.1
IS there any improvements on the Blend command?
Thank you
Roger
8966.26 In reply to 8966.25
Hi Roger,
There are no changes to the Blend command in this beta release.
8966.27 In reply to 8966.9
Hi Marco,
re: MF2018.STEP file that gets stuck loading at 36% - I've got that fixed up now for the next v4 beta. There was a Solids++ function that could be slow to process certain kinds of trim boundaries. I've rewritten it with an improved version that does not get bogged down anymore.
Thanks for reporting the bug and sending the file for me to test with!
8966.28 In reply to 8966.27
You're welcome Michael!
Good to know that you have fixed that issue :)
8966.29
Great loading speedup Michael. Massive speed benefits on my DualXeons also.
I got 3x,4x, and even 5x on some STEP models.
Kudos
Lewis
www.ram-studio.hr
Skype - lewis3d
8966.30
Cool now also imports the colors of the objects, very well, great.
8966.31 In reply to 8966.29
@Lewis,
Sounds fantastic Lewis, thanks for testing it!
@pafurijaz - yes that Raspberry Pi board that you wrote about previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8936.27
should be working ok now.
8966.32 In reply to 8966.1
Greetings Michael thanks for the great update.
Pardon my ignorance, Please tell me how to use the the numbers followed by (ms) that appear in the upper left of each viewport.
Thanks. Cheers!!
8966.33 In reply to 8966.32
<< by (ms) that appear in the upper left of each viewport
I believe it's just info for the moment of display's speed between each use of function ! ;)
8966.34 In reply to 8966.32
Hi phlatt5th,
That's the number of milliseconds it took to draw the last viewport screen image.
It's used to compare the results of performance work to get a numeric measure of whether things are faster or slower instead of just going by feel.
It won't be on for too much longer, just until some last display performance work in v4 is done.
8966.35 In reply to 8966.34
@ Pilou and Michael. Thank you for the clarification.
Cheers.
8966.36 In reply to 8966.20
16Mb STEP file loaded into 3.0 took ~15 minutes to load. Same file in 4.0 beta took ~1.5 minutes. STEP file import, edit and conversion makes up the bulk of my work with MoI, so this is a really welcomed improvement!
8966.37 In reply to 8966.36
That's great Branden, thanks for testing it!
8966.38
Hi Michael.
Problem. Draw a curve of several arcs, connect, divide. Some arcs remained crooked.
Is it possible to solve this problem.
The file is attached.
Vladimir.
8966.39 In reply to 8966.38
Hi Vladimir,
I'm sorry I'm not understanding what the problem is - I thought maybe you meant some operation was causing your curves to become crooked? But in your file it looks like they are starting out crooked to begin with?
8966.40
Hello,
I notice a small oddity with the interface loading collapsed completely in the latest beta. When double clicking a STEP file from the file manager in Windows all of the menus are collapsed and the window size is something other than maximized. This happens for all STEP files. 3DM files do not exhibit this behavior when opened via the file manager. Loading STEP files through the MoI Open dialog works as expected.
8966.41 In reply to 8966.40
Hi OSTexo, thanks for reporting this bug, I can repeat it over here too.
It's a side effect from STEP file import now showing some UI during the loading process, it will need to wait for just a moment until the main window is fully initialized before loading the file. Shouldn't be difficult to fix.
Thanks, - Michael
8966.42 In reply to 8966.39
Hi Michael.
Look at the file, I changed it, maybe it will be clearer.
Show messages:  1-2  3-22  23-42  43-62  63-68
