V4 beta Jun-6-2018 available now
 1-18  19-38  39-58  59-68
Release notes in first message have been updated. - Michael
8966.20 In reply to 8966.1
Hello Michael!
@You : "...Update viewport right click - Don't push Cancel buttons with a viewport right click, it's too easy to accidentally cancel a long file import or things like that..."
This is OK for me!
8966.22 In reply to 8966.21
Very nice picture again!!
8966.23 In reply to 8966.19
I have adjusted the grip frames size in the Moi.ini file and much better visibility.
Many thanks
Barry
I increased EditFrameGripPixelSize to 32. Much easier to find the frame handles on my widescreen monitor - Thanks!
8966.25 In reply to 8966.1
IS there any improvements on the Blend command?
Thank you
Roger
8966.26 In reply to 8966.25
Hi Roger,
There are no changes to the Blend command in this beta release.
8966.27 In reply to 8966.9
Hi Marco,
re: MF2018.STEP file that gets stuck loading at 36% - I've got that fixed up now for the next v4 beta. There was a Solids++ function that could be slow to process certain kinds of trim boundaries. I've rewritten it with an improved version that does not get bogged down anymore.
Thanks for reporting the bug and sending the file for me to test with!
8966.28 In reply to 8966.27
You're welcome Michael!
Good to know that you have fixed that issue :)
8966.29
Great loading speedup Michael. Massive speed benefits on my DualXeons also.
I got 3x,4x, and even 5x on some STEP models.
Kudos
Lewis
www.ram-studio.hr
Skype - lewis3d
8966.30
Cool now also imports the colors of the objects, very well, great.
8966.31 In reply to 8966.29
@Lewis,
Sounds fantastic Lewis, thanks for testing it!
@pafurijaz - yes that Raspberry Pi board that you wrote about previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8936.27
should be working ok now.
8966.32 In reply to 8966.1
Greetings Michael thanks for the great update.
Pardon my ignorance, Please tell me how to use the the numbers followed by (ms) that appear in the upper left of each viewport.
Thanks. Cheers!!
8966.33 In reply to 8966.32
<< by (ms) that appear in the upper left of each viewport
I believe it's just info for the moment of display's speed between each use of function ! ;)
8966.34 In reply to 8966.32
Hi phlatt5th,
That's the number of milliseconds it took to draw the last viewport screen image.
It's used to compare the results of performance work to get a numeric measure of whether things are faster or slower instead of just going by feel.
It won't be on for too much longer, just until some last display performance work in v4 is done.
8966.35 In reply to 8966.34
@ Pilou and Michael. Thank you for the clarification.
Cheers.
8966.36 In reply to 8966.20
16Mb STEP file loaded into 3.0 took ~15 minutes to load. Same file in 4.0 beta took ~1.5 minutes. STEP file import, edit and conversion makes up the bulk of my work with MoI, so this is a really welcomed improvement!
8966.37 In reply to 8966.36
That's great Branden, thanks for testing it!
8966.38
Hi Michael.
Problem. Draw a curve of several arcs, connect, divide. Some arcs remained crooked.
Is it possible to solve this problem.
The file is attached.
Vladimir.
Show messages:  1-18  19-38  39-58  59-68
