V4 beta Jun-6-2018 available now
 1-11  12-31  32-51  52-68
8966.12
Anyone has experienced the problem of mouse right click to cancel the command?
In my case, I cannot cancel some commands using right mouse click.
Line or Freeform curve have no problem.(sometimes)
But closed curve like circle and rectangle cannot be canceled using right mouse click.
And other commands have same problem.
That's very weird. :(
EDITED: 7 Jun 2018 by JEONGHO_KIM
8966.13 In reply to 8966.12
Hi sandykoufax - this version has right click to push the cancel button disabled now, I have heard from a few people that it was not expected and I was worried about accidentally canceling file loading with it as well. If a command is showing a "Done" button instead of only a "Cancel" button, right click still works as a shortcut for pushing that.
I will put in an option though to restore the previous behavior for the next release.
8966.14
Hi Micheal
I tested on stop file 219mb in size.
V3 = 13:06 mins
V4 = 2:22 mins !!!!
I am on a iMac 4Ghz Intel Core i7, 32 gb memory, AMD Radeon R9 M395X 4GB
This is great news, so much so that I really think that you should utilise email software notifications a little more, I check the forums quite regularly but progress like this really should be broadcast more widely :-)
Oh and the colours coming coming thru just made my work a whole lot easier by being able to break complex models into easier sections for export etc.
Well done, much appreciated.
Matt
8966.15 In reply to 8966.13
Thank you for answer.
It was very very annoying for me.
So I reverted my version to previous one.
I hope the new behavior is option instead of default in next version. :)
8966.16 In reply to 8966.15
Hi sandykoufax, it could help me if I understood why the right click to cancel was useful. If you start the circle command for example, how is it that you then don't want to draw a circle anymore? I mean is it because you meant to actually run some other command and you were in the circle command by mistake? Or is it something else?
You can also cancel the circle command by pushing the Cancel button, using the Esc key or just starting a new command which will cancel the current one.
The main reason for the switch was that now the Open and Import commands will show some UI with a cancel button on it, and right clicking in a viewport would then cancel the file load which doesn't seem good to do.
8966.17 In reply to 8966.16
Because that it was default workflow for a long time.
Something change give some inconvenience until it gets used to it.
8966.18 In reply to 8966.17
Hi sandykoufax,
Certainly, and that's why I'll definitely set it up so you can do a one time configuration step and then return to the old behavior after that.
But whether it should be the default or not depends a lot on how much inconvenience is involved in normal usage, like is it once a day, once and hour, once a minute, etc... ?
Release notes in first message have been updated. - Michael
8966.20 In reply to 8966.1
Hello Michael!
@You : "...Update viewport right click - Don't push Cancel buttons with a viewport right click, it's too easy to accidentally cancel a long file import or things like that..."
This is OK for me!
Thanks.
8966.22 In reply to 8966.21
Very nice picture again!!
8966.23 In reply to 8966.19
I have adjusted the grip frames size in the Moi.ini file and much better visibility.
Many thanks
Barry
I increased EditFrameGripPixelSize to 32. Much easier to find the frame handles on my widescreen monitor - Thanks!
8966.25 In reply to 8966.1
IS there any improvements on the Blend command?
Thank you
Roger
8966.26 In reply to 8966.25
Hi Roger,
There are no changes to the Blend command in this beta release.
8966.27 In reply to 8966.9
Hi Marco,
re: MF2018.STEP file that gets stuck loading at 36% - I've got that fixed up now for the next v4 beta. There was a Solids++ function that could be slow to process certain kinds of trim boundaries. I've rewritten it with an improved version that does not get bogged down anymore.
Thanks for reporting the bug and sending the file for me to test with!
8966.28 In reply to 8966.27
You're welcome Michael!
Good to know that you have fixed that issue :)
Thanks.
8966.29
Great loading speedup Michael. Massive speed benefits on my DualXeons also.
I got 3x,4x, and even 5x on some STEP models.
Kudos
Lewis
www.ram-studio.hr
Skype - lewis3d
8966.30
Cool now also imports the colors of the objects, very well, great.
8966.31 In reply to 8966.29
@Lewis,
Sounds fantastic Lewis, thanks for testing it!
@pafurijaz - yes that Raspberry Pi board that you wrote about previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8936.27
should be working ok now.
Show messages:  1-11  12-31  32-51  52-68
