3-Point-Align Script
All  1-6  7-11
8945.7 In reply to 8945.5
Hi Ray - so here's the way to do a 3 point align.
1 - Place origin point at your first reference point.
2 - Click (click and release the mouse, not drag) on the orientation picker's x axis line. It is now the primary axis which can be oriented in any direction.
3 - Drag on the x axis line and release it on your second reference point.
4 - Drag on the y axis line and release it on your third reference point.
8945.8 In reply to 8945.7
I follow your instructions video and I made the 3D Ball with your help. I am so happy that I made it. I just take 5 minutes to do it.
Yes, the first file that I sent you was mislead measures but I correct them. The one that I send you is correct and good measures.
Thank you for your help and support.
regards,
Ray
8945.9 In reply to 8945.8
You're welcome Ray, I'm glad that worked for you!
8945.10
https://www.bilibili.com/video/BV1Yp421U762/?spm_id_from=333.999.0.0
https://www.bilibili.com/video/BV1Zq4y197ii?p=7&vd_source=913e265b028433d7f4030496da189d83
我做的,关于标准足球建模并上色的最快方法。moi3d的问题是被轮廓边缘穿过的面实际会被分割(rhino也有这个问题),导致这些面不能倒角(fillet)成功。因此应该采用圆形阵列来做。(第二个视频展示了如何通过旋转避开球的轮廓边缘)
EDITED: 17 May 2024 by SUIYAN
Size: 102 KB, Downloaded: 39 times, Dimensions: 846x576px
Size: 130.3 KB, Downloaded: 55 times, Dimensions: 522x524px
Size: 200.1 KB, Downloaded: 38 times, Dimensions: 601x609px
Size: 179.9 KB, Downloaded: 45 times, Dimensions: 1026x811px
8945.11 In reply to 8945.10
This must be a coincidence in time, I did the same thing but without using the script but construction lines this morning.
but the script is useful
soccer_ball</mg>
Show messages: All  1-6  7-11
