Electronics Enclosure Designed in MoI
All  1  2-10
8944.2 In reply to 8944.1
Hi Ed, it turned out great!
How has the Robo printer been working for you, looks like you're getting good results with it.
Also what does the device that you've made do?
8944.3 In reply to 8944.2
The Robo 3D printer works great and the Simplify3D Slicer program plays well with MoI.
What I have to learn to do better is add gap tolerances where pieces join together. For example, if a power receptacle is 1" x 2" and I model it as such and Boolean Diff it with the box to make an opening, the receptacle won't fit. I have to temporarily enlarge the receptacle model so the resulting hole will be slightly larger. Maybe there is an opportunity for a specialized Boolean Diff script: Temporarily enlarge cutting object by x%, or enlarge cutting object by x thousandths of an inch in all dimensions, just while doing the Boolean Diff. After the Boolean, the object automatically reverts back to original size.
The fixture is for powder coating very small metal parts in a precisely controlled, even & repeatable way without using a clumsy, messy, hard to control, hand-held powder coating gun. I can't share the entire process and related custom hardware for competitive reasons, but it works very well :)
EDITED: 20 May 2018 by EDDYF
I also wanted to share how I made the basic solid object for the box lid all in one go. Draw the profile curve and the lid perimeter curve with beveled corners.
Then Rail Revolve. Easy!
8944.5 In reply to 8944.4
+1 to Ed's idea for a Boolean command that shrinks or expands .
MOI does drawings with practically zero tolerance , things fit in its (almost :)) perfect world , but when going to 3D printing there are all kinds of tolerances that stack making parts that fit or interlock together tricky , inside holes need to fit to outside diameters . So some kind of Boolean tolerance tool would be a real help.
PS MOI rocks for 3D printing
8944.6 In reply to 8944.5
Hi Ed & DigiD - a shrink or expand thing like that is unfortunately very difficult. You can't form it by scaling, it would need to be done by offset.
8944.7 In reply to 8944.1
Excellent work - nice job!
8944.8
Awesome!
8944.9
Always great to see a digital design come to life. Everything looks very neat inside the box, congrats man.
8944.10
That is really cool thanks for sharing and showing other opportunities with MOI
Show messages: All  1  2-10
