Newb: help with Arm and belly contours for solid body guitars
 1-13  …  54-73  74-93  94-99
8938.94 In reply to 8938.93
Great stuff Neil, thank you for sharing some of your fabrication details!
8938.95 In reply to 8938.92
Hi Ed - One of my customers does the photography in exchange for a custom guitar. He does it professionally.
8938.96 In reply to 8938.19
Thanks again for this - still using this technique and it makes gorgeous arm contours. :)
8938.97 In reply to 8938.93
That's some beautiful work you are doing there - I think your photographer is getting a good deal!
I have Estlcam and Deskproto and it's surprising what these two apps are capable of. I suppose you are aware Deskproto has a free version https://www.deskproto.com/products/comptable.php (quite limited, but useful nonetheless), but the full version is very capable so it would suit your work well.
Just for information to anyone interested, the hobby version can be used commercially as long as sales amount to no more than EUR 3000 https://www.deskproto.com/order/licenseagreement.php
Other CAM apps I find to be very good are CamBam https://cambamcnc.com/ & Ecam. CamBam would probably do everything you would need as it has quite strong 3D capability along with excellent 2/2.5D functionality.
I use Ecam https://v4.e-cam.it/ for milling and turning which again I find to be full-featured and nice to use. All these CAMs have strengths over each other, so I sometimes use them in combination, depending on what I need to do.
If you would like to compare the gcode of one of your parts running through any of these CAM apps, then just mention it here and I'll give it a go.
Martin.
8938.98 In reply to 8938.97
Thanks Martin,
I need to upgrade the CAM program. Estlcam is little limited - although it has been amazing for the price. I own CamBam but the learning curve is a little bit steep for someone with very little free time. That said, I try to spend a little time with it when I can. CamBam's interface seems a little cumbersome to me. Estlcam can spoil you because it is so intuitive. I'm torn between Deskproto and V-Carve pro - they are in the same price range but V-carve pro seems geared more toward the woodworker. Opinion?
Many thanks for the post Martin!
8938.99
Another guitar. Nothing new here - but I thought it turned out nice.
EDITED: 19 Jan 2024 by VEGASGUITARS
Size: 392.6 KB, Downloaded: 53 times, Dimensions: 1920x1080px
Size: 437.1 KB, Downloaded: 62 times, Dimensions: 1920x1080px
Size: 271.1 KB, Downloaded: 52 times, Dimensions: 1500x524px
Size: 242.1 KB, Downloaded: 52 times, Dimensions: 1500x526px
Show messages:  1-13  …  34-53  54-73  74-93  94-99
