Newb: help with Arm and belly contours for solid body guitars
 1-8  9-28  29-48  49-68  69-88  89-99
Unreal to reality! Excellent!
My Moi French Site My Gallery
8938.30 In reply to 8938.26
Fantastic neck Neil!
Marc
Looks great!
Always fun to see a MoI 3D model translated into a physical object whether it be in wood, metal, foam, or 3D printed plastic.
8938.32
A couple low res renderings of the body and neck made with MoI3D - looking forward to more challenging endeavors after building this guitar. The body is a tad too thick and a few other things that need to be redesigned for production - but all in all pretty good thanks to the generous sharing of information here.
EDITED: 15 Apr 2019 by VEGASGUITARS
8938.33 In reply to 8938.32
Hmmm...honestly, not so good those renderings...
They fail to do justice to the very nice and very well done original product!
Bad material setup.
8938.34 In reply to 8938.33
Obviously don't know much about rendering - sorry for the poor quality here are the pictures in MoI.
EDITED: 10 Jun 2018 by VEGASGUITARS
8938.35 In reply to 8938.34
Very good modelling!!
And about renderings...no one is born knowing everything :)
A very good knowledge of the rendering' principles takes months to be learned...and a lot, lot of practicing :)
8938.36 In reply to 8938.35
Thank you for all the input and suggestions Marco! Well noted.
8938.37
This is so awesome, being able to build the entire guitar as it was modeled in MOI! Seeing this I'm starting to think that NURBS modelling is actually the better paradigm (even for semi-organic shapes), if one can "escape" the polygonal mindset.
8938.38
a few improved renders - using SimLab free edition.
EDITED: 26 Apr 2019 by VEGASGUITARS
Size: 273.4 KB, Downloaded: 86 times, Dimensions: 1050x483px
Size: 180.3 KB, Downloaded: 87 times, Dimensions: 1050x408px
8938.39 In reply to 8938.38
Hello!
A pretty simple material setup, but very nice render this time :)
8938.40 In reply to 8938.39
Thanks Marco, Yes - still not great - but better - have a lot to learn :)
8938.41 In reply to 8938.40
You're welcome.
Anyway, beyond the rendering, it's a very good 3d model.
I don't remember well but maybe in Simlab Composer there's some procedural material that doesn't require UV map.
Check it out.
For very quick rendering with simple material setup, but anyway with a very good quality, I often use the "Shaders" in 3D-Coat.
They don't require any UV map and are applied directly to the hi-poly mesh object (either Voxel or standard polygonal model)
Ciao!
8938.42 In reply to 8938.41
Thanks for the tips on rendering - much appreciated.
8938.43 In reply to 8938.42
You're welcome VEGASGUITARS.
8938.44
Here's a new routing scheme for the "Ione" model - this one has three single coil pickup slots and a tremolo cavity . . . working on the pickguard.
EDITED: 24 Jul 2018 by VEGASGUITARS
Size: 132.5 KB, Downloaded: 45 times, Dimensions: 950x623px
Size: 101 KB, Downloaded: 50 times, Dimensions: 950x650px
Size: 79.6 KB, Downloaded: 47 times, Dimensions: 950x662px
8938.45 In reply to 8938.44
Here's the Ione model with humbuckers and two volume two tone control spaces. The hope is to mill the three designs in several scale lengths and send them to Premier magazine.
Size: 93.9 KB, Downloaded: 62 times, Dimensions: 950x699px
Size: 106.6 KB, Downloaded: 48 times, Dimensions: 1000x627px
Size: 56.7 KB, Downloaded: 57 times, Dimensions: 950x668px
8938.46 In reply to 8938.45
Very high quality model!! Congrats!!
8938.47 In reply to 8938.46
Thanks Marco!
8938.48
Having trouble filleting the back of this model - any suggestions? The top is fine. Thanks for the help.
EDITED: 21 Feb 2021 by VEGASGUITARS
Size: 82.8 KB, Downloaded: 49 times, Dimensions: 1093x863px
Size: 107.9 KB, Downloaded: 38 times, Dimensions: 1269x941px
Size: 102 KB, Downloaded: 58 times, Dimensions: 1596x956px
Show messages:  1-8  9-28  29-48  49-68  69-88  89-99
