Scaling question
All
1-3
4-5
Colin
2 May 2018 (4 of 5)
8927.4
Hi Gunter,
As noted by Finema & Michael, use the Offset...
...but note that curves created by Offset will be Points heavy...
...so select your offset curve & use Rebuild to reduce the Points.
HTH, Colin
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
gunter511
4 May 2018 (5 of 5)
8927.5
Hi All,
great, thanks for the solution. Offset is the obvious choice... duh!
It's weird I've used offset so many times for similar work but it just never popped into that hold head of mine. Go figure :)
Many thanks
Gunter
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-5
