Shaded View
All  1  2-7
8923.2 In reply to 8923.1
Hi Kevin, re: shaded viewport - the way I like to do it is with this shortcut key set for the Space bar:
SaveAs c:\test.obj
that will trigger a save to an .obj file but not ask you for the filename since it's given as a command line parameter. Set the display option in the meshing options dialog to Display : Shaded and hit cancel when you're done.
Another way is to hide all edges, that can be done using the Scene browser under Types > Edge , or set up a shortcut key with the script from here:
http://kyticka.webzdarma.cz/3d/moi/#ShadedDisplayMode , that's probably what was used in the tutorials you saw.
8923.3
Thanks Michael.
8923.4
It would be amazing if MOI had real time ambient Occlusion in the viewport like Cinema4d or Magica Voxel. I find the current viewport settings quite cold and unwelcoming. Although very functional the current display doesn't compliment the rest of the inspirational and amazing creative workflow that MOI has. I tried messing around with all the lighting settings but all I really get is shinier models :) I'd love it to have options for a more natural look. Myabe its just me but I get a boost when I'm rotating around my models untextured and they already look great.
I'm thinking also Magica Voxel as a good realtime viewport reference..see below..
That and real time booleans. :)
8923.5 In reply to 8923.4
Hi Simon, unfortunately both of those things can have a detrimental effect on performance especially on more complex models. So I'd expect them to take quite a bit of development time to do a good job on them. Because of that I'm not sure when I'll be able to work on those areas.
8923.6 In reply to 8923.5
michael will u share ? mb users will improve shaders and visual aspects !
8923.7 In reply to 8923.6
Hi Cemortan_Tudor,
Share what?
Show messages: All  1  2-7
