Zarkow’s Sub D
 1-3  4-23  24-43  44-47
8916.44 In reply to 8916.43
ok..Run the first time....Stop ... Apply ...Clear/Update (for input a new the selection)... make the trick..
even direct selection don't work for me...
But for go out the node for use the result i must use this (not a big deal)... is that the same for you ?
script:/*go out nodes*/ var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true );
EDITED: 11 Aug 2023 by PILOU
seems not working on a complete native sphere!
LineWeb + CMorph can also be a canditate for facetting when you know the number wanted of the divisions edges curves side! :)
And will works where JFHSubd entangles for strange surfaces :)
EDITED: 12 Aug 2023 by PILOU
PS Quads generated on the Zarkow's car are specially planar or not ?
EDITED: 13 Aug 2023 by PILOU
Show messages:  1-3  4-23  24-43  44-47
