Zarkow’s Sub D
 1-19  20-39  40-47
8916.40 In reply to 8916.39
images in background are well sliding so we can see the nodes graph !
but no comfortably! :)
8916.41 In reply to 8916.34
JFHSubD2
Does this the normal use ?
Select a surface
Load the Node ...Run
Select another surface
Load the Node...Run
etc...
8916.43 In reply to 8916.42
The Node Editor can stay open. Just change surface selections.
Slow this down on YouTube
https://moi3d.com/forum/index.php?webtag=MOI&msg=10756.19
8916.44 In reply to 8916.43
ok..Run the first time....Stop ... Apply ...Clear/Update (for input a new the selection)... make the trick..
even direct selection don't work for me...
But for go out the node for use the result i must use this (not a big deal)... is that the same for you ?
script:/*go out nodes*/ var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true );
EDITED: 11 Aug 2023 by PILOU
seems not working on a complete native sphere!
LineWeb + CMorph can also be a canditate for facetting when you know the number wanted of the divisions edges curves side! :)
And will works where JFHSubd entangles for strange surfaces :)
EDITED: 12 Aug 2023 by PILOU
PS Quads generated on the Zarkow's car are specially planar or not ?
EDITED: 13 Aug 2023 by PILOU
Show messages:  1-19  20-39  40-47
