Zarkow’s Sub D
 1-3  4-23  24-43  44-47
8916.4 In reply to 8916.3
... great, I think now at the latest it's time to take a closer look at Nodeeditor...
Franz
8916.5
This is fantastic
8916.6
Update,
as a test I used subD smoothing on Neil's Guitar Head that I had
created using networked surfaces.
As long as the surfaces are 4 sided networks it works great.
There were some panels that needed rebuilding but not many
and after that managed to get a solid.
So thanks James your macro and Max's nodeeditor certainly
shortens the workflow.
Barry
8916.7 In reply to 8916.6
That is awesome - how did you do that?
8916.8 In reply to 8916.7
Hi Neil,
I took the networked head ran thro the surfaces one by one with the
nodeeditor and James macro nod converting them to panelled surfaces.
Joined all the panelled surfaces.
Some correction was necessary ie: some panels when the sub D
was applied didn't convert properly so it was necessary to delete
and rebuild them. Also I used the ssplit tool to maintain sharper
edges.
I have no sub D modelling experience so it may be I could have
used less divisions.
Barry
8916.9 In reply to 8916.8
Really like the results you're getting here - this is new territory for me. But it's quite fascinating. Thanks for sharing.
8916.10 In reply to 8916.2
Hello @Barry-H, (or maybe @Michael could help too)
I know Nodeditor is under development and it is getting updated from time to time. However, I want to know how can I use "JFHSubD.nod"
I have downloaded "extensions.zip" from your post.
But I already have an extension folder in here: "C:\Users\My_Computer\AppData\Roaming\Moi\nodeeditor\nodes\extensions"
I looked into these folders and I noticed the files that reside there are different because I don't want to mess up the files in my extensions folder I am reaching out to you and asking for your guidance.
Another issue I have is that the retopoSurfs node seems not working in my nodeeditor window after I loaded "JFHSubD.nod" into it.
Best,
Psygorn (DRILLBIT)
8916.11 In reply to 8916.10
Hi Psygorn
the retopoSurfs node is a macro and when opened the concat2 node needs replacing with the basic concat node plus the
intersecobj node needs replacing but I'm not sure how to rewire the new node in.
Hopefully James will see this post and update the node.
Barry
8916.12 In reply to 8916.10
My advice will be make a new Node Editor folder for this specific SubD node!
a folder Node Editor is something like 1 Mega so not a big deal to make one more!
Save the older... like this you will no be afraid to make some mess somewhere in your files!
At the end just rename (or not) as you wish...
it's was my process for many different use! :)
8916.13 In reply to 8916.10
EDITED: 7 Dec 2022 by BEMFARMER
Message 8916.15 deleted 7 Dec 2022 by WN
8916.16
A small note.
For a more convenient navigation through the node diagram, place the diagram or its important part in the editor frame.
When you upload a file to the editor or exit the macro, the editor focuses on this frame.
This will make it easier for you and those who use your '.nod' file.
image host
image host
8916.17 In reply to 8916.11
Barry,
Yes the macro "retopoSurfs" is deprecated/obsolete.
I have a more recent macro "Retopologize" which works in its place.
Please find .nod file attached.
8916.18 In reply to 8916.17
James,
thanks works fine.
Barry
8916.19 In reply to 8916.10
Hi Psygorn (DRILLBIT).
You can also revive an old file. There is a file in the archive 'objects3.js ' extract it to the folder where your 'Nodeeditor' is located.
In many macros from this forum, you will encounter nodes from this file. For example 'Concat2'.
I attached this file at the bottom.
image host image host
8916.20
Hello guys,
Thank you all for your help and guidance.
However, I am in need of your help again.
Please take a look at the attached file. I tried to retopologize the surfaces you would find in the attached files they are named: "1" "2" & "3" surfaces "2 and "3" are joined surfaces (so they consist of two sub surfaces)
When I try to use either JFHsubD.nod or JFHsubD2.nod I cannot get a good retopologized surfaces out of surfaces "2" and "3" if there is a solution to this problem I would by happy if u let me know what that is! :-)
Best,
Psygorn/Drillbit
8916.21 In reply to 8916.20
Hi Psygorn,
it does not work on joined surfaces also the surfaces must have 4 edges only.
You can rebuild your surfaces with network.
Also set 'U' and 'V' to the same as some times the surface U V are opposite.
Barry
8916.22 In reply to 8916.21
Tanx Barry-H
8916.23 In reply to 8916.12
Hi PILOU,
Do you have older versions of Nodeeditor? Where can I get them? Most links refer back to Max's original blog and you know it's almost a year that his weblog is out of reach!
Best,
Psygorn(Drillbit)
Show messages:  1-3  4-23  24-43  44-47
