Zarkow’s Sub D
 1-13  14-33  34-47
8916.34 In reply to 8916.33
I have the desire, but I don't have the knowledge and skills!
8916.35 In reply to 8916.34
Psygorn, the knowledge and skills of those guys that I mentioned above and many other smart people also did not appear by themselves.
As long as there is a desire, then everything will be fine.
8916.36
Hi Psygorn
I changed your node a bit.
See if it helps.
8916.37 In reply to 8916.36
Hi MO_TE,
That's interesting thank u!
Message 8916.38 deleted 8 Mar 2023 by JFH
8916.39 In reply to 8916.33
quote:
James first shared his works, but then deleted them.
It was not the case that there was a wholesale deletion of my archive of demos, but rather I was continuously freeing up space before each new post because I quickly reached the limit of my forum data allowance.
I moved my NE demonstrations to instagram in large part due to this frustration, but also to evangelise for NodeEditor & MoI3d to a wider audience . My motives were purely out of self-interest: I thought if we could grow the user-base for NodeEditor, it would accelerate its development.
Obviously, instagram posts don't have the facility for attachments, but as apparent here, the issue of NE uptake & version inconsistency invariably meant that often my .NOD files did not work for others.
I have long felt that I should take the reins of this project and finally get it out of beta phase, but I have been too busy to devote the necessary time, and not being a coder, it is not something I could do alone. I still have great faith in NE.
EDITED: 9 Mar 2023 by JFH
8916.40 In reply to 8916.39
images in background are well sliding so we can see the nodes graph !
but no comfortably! :)
8916.41 In reply to 8916.34
JFHSubD2
Does this the normal use ?
Select a surface
Load the Node ...Run
Select another surface
Load the Node...Run
etc...
8916.43 In reply to 8916.42
The Node Editor can stay open. Just change surface selections.
Slow this down on YouTube
https://moi3d.com/forum/index.php?webtag=MOI&msg=10756.19
8916.44 In reply to 8916.43
ok..Run the first time....Stop ... Apply ...Clear/Update (for input a new the selection)... make the trick..
even direct selection don't work for me...
But for go out the node for use the result i must use this (not a big deal)... is that the same for you ?
script:/*go out nodes*/ var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true );
EDITED: 11 Aug 2023 by PILOU
seems not working on a complete native sphere!
LineWeb + CMorph can also be a canditate for facetting when you know the number wanted of the divisions edges curves side! :)
And will works where JFHSubd entangles for strange surfaces :)
EDITED: 12 Aug 2023 by PILOU
PS Quads generated on the Zarkow's car are specially planar or not ?
EDITED: 13 Aug 2023 by PILOU
Show messages:  1-13  14-33  34-47
