Zarkow’s Sub D
 1  2-21  22-41  42-47
8916.22 In reply to 8916.21
Tanx Barry-H
8916.23 In reply to 8916.12
Hi PILOU,
Do you have older versions of Nodeeditor? Where can I get them? Most links refer back to Max's original blog and you know it's almost a year that his weblog is out of reach!
Best,
Psygorn(Drillbit)
8916.24 In reply to 8916.23
8916.25 In reply to 8916.24
Thank you PILOU,
For anyone who can help (especially James or WN) ->
I have a question: instead of Idselect and concat what should I use?
EDITED: 5 Mar 2023 by DRILLBIT
8916.26 In reply to 8916.25
Hi Psygorn.
Depends on what needs to be done. Show the file or drawing of your task.
It happens that the problem can be solved in different ways.
8916.27 In reply to 8916.26
Hi WN,
I wanted to recreate one of James works here: https://www.instagram.com/p/CY6P8lDr0tW/
But I did not end up with the same results I think it is because of concat2 that I used in my Nod file.
8916.28 In reply to 8916.27
concat2 shows as red colour indicating its obsolete in my nodeditor.
You can replace it with the basics concat node and right click on it to change its operation to numbers.
Delete the concat2 node as the nodeditor will not run with obsolete nodes present.
Barry
8916.29 In reply to 8916.27
Hi Psygorn.
The "concat" node only collects the numbers in the order of connection and passes them on, in this case it does not matter whether it is old or new.
Most likely, the "MathPts" node has formulas and they are visible only in the properties widget.
I do not know this formula.
There is also a 'mode' setting in the nodes it also affects the result.
image host
image host
8916.30 In reply to 8916.29
Hi WN,
I had this idea to recreate what James has done on his instagram, and then latter share it with others who want to study nodeeditor and nodes ; but now I think it would be a very hard task! Maybe only james can share his works!
What do u think?
Also, I tried to put the parametric formula for "trefoil knot" in Mathpoints node but it still doesn't give me what I want (Jame's Instagram post). (check the attached node file)
8916.31 In reply to 8916.28
I used Concat node but I cannot even get it connected to the following nodes: Math & MathPts.
8916.32 In reply to 8916.31
Right-click on the node, a menu will appear, choose what you need.
8916.33 In reply to 8916.30
Psygorn, James first shared his works, but then deleted them.
Max was also available at first, now the site is not working.
I think we should go our own way, but it will end sometime.
If you have the desire and the time, do it.
8916.34 In reply to 8916.33
I have the desire, but I don't have the knowledge and skills!
8916.35 In reply to 8916.34
Psygorn, the knowledge and skills of those guys that I mentioned above and many other smart people also did not appear by themselves.
As long as there is a desire, then everything will be fine.
8916.36
Hi Psygorn
I changed your node a bit.
See if it helps.
8916.37 In reply to 8916.36
Hi MO_TE,
That's interesting thank u!
Message 8916.38 deleted 8 Mar 2023 by JFH
8916.39 In reply to 8916.33
It was not the case that there was a wholesale deletion of my archive of demos, but rather I was continuously freeing up space before each new post because I quickly reached the limit of my forum data allowance.
I moved my NE demonstrations to instagram in large part due to this frustration, but also to evangelise for NodeEditor & MoI3d to a wider audience . My motives were purely out of self-interest: I thought if we could grow the user-base for NodeEditor, it would accelerate its development.
Obviously, instagram posts don't have the facility for attachments, but as apparent here, the issue of NE uptake & version inconsistency invariably meant that often my .NOD files did not work for others.
I have long felt that I should take the reins of this project and finally get it out of beta phase, but I have been too busy to devote the necessary time, and not being a coder, it is not something I could do alone. I still have great faith in NE.
EDITED: 9 Mar 2023 by JFH
8916.40 In reply to 8916.39
images in background are well sliding so we can see the nodes graph !
but no comfortably! :)
8916.41 In reply to 8916.34
Show messages:  1  2-21  22-41  42-47
