Zarkow’s Sub D
 1-14  15-34  35-47
Message 8916.15 deleted 7 Dec 2022 by WN
8916.16
A small note.
For a more convenient navigation through the node diagram, place the diagram or its important part in the editor frame.
When you upload a file to the editor or exit the macro, the editor focuses on this frame.
This will make it easier for you and those who use your '.nod' file.
image host
image host
8916.17 In reply to 8916.11
Barry,
Yes the macro "retopoSurfs" is deprecated/obsolete.
I have a more recent macro "Retopologize" which works in its place.
Please find .nod file attached.
8916.18 In reply to 8916.17
James,
thanks works fine.
Barry
8916.19 In reply to 8916.10
Hi Psygorn (DRILLBIT).
You can also revive an old file. There is a file in the archive 'objects3.js ' extract it to the folder where your 'Nodeeditor' is located.
In many macros from this forum, you will encounter nodes from this file. For example 'Concat2'.
I attached this file at the bottom.
image host image host
8916.20
Hello guys,
Thank you all for your help and guidance.
However, I am in need of your help again.
Please take a look at the attached file. I tried to retopologize the surfaces you would find in the attached files they are named: "1" "2" & "3" surfaces "2 and "3" are joined surfaces (so they consist of two sub surfaces)
When I try to use either JFHsubD.nod or JFHsubD2.nod I cannot get a good retopologized surfaces out of surfaces "2" and "3" if there is a solution to this problem I would by happy if u let me know what that is! :-)
Best,
Psygorn/Drillbit
8916.21 In reply to 8916.20
Hi Psygorn,
it does not work on joined surfaces also the surfaces must have 4 edges only.
You can rebuild your surfaces with network.
Also set 'U' and 'V' to the same as some times the surface U V are opposite.
Barry
8916.22 In reply to 8916.21
Tanx Barry-H
8916.23 In reply to 8916.12
Hi PILOU,
Do you have older versions of Nodeeditor? Where can I get them? Most links refer back to Max's original blog and you know it's almost a year that his weblog is out of reach!
Best,
Psygorn(Drillbit)
8916.24 In reply to 8916.23
8916.25 In reply to 8916.24
Thank you PILOU,
For anyone who can help (especially James or WN) ->
I have a question: instead of Idselect and concat what should I use?
EDITED: 5 Mar 2023 by DRILLBIT
8916.26 In reply to 8916.25
Hi Psygorn.
Depends on what needs to be done. Show the file or drawing of your task.
It happens that the problem can be solved in different ways.
8916.27 In reply to 8916.26
Hi WN,
I wanted to recreate one of James works here: https://www.instagram.com/p/CY6P8lDr0tW/
But I did not end up with the same results I think it is because of concat2 that I used in my Nod file.
8916.28 In reply to 8916.27
concat2 shows as red colour indicating its obsolete in my nodeditor.
You can replace it with the basics concat node and right click on it to change its operation to numbers.
Delete the concat2 node as the nodeditor will not run with obsolete nodes present.
Barry
8916.29 In reply to 8916.27
Hi Psygorn.
The "concat" node only collects the numbers in the order of connection and passes them on, in this case it does not matter whether it is old or new.
Most likely, the "MathPts" node has formulas and they are visible only in the properties widget.
I do not know this formula.
There is also a 'mode' setting in the nodes it also affects the result.
image host
image host
8916.30 In reply to 8916.29
Hi WN,
I had this idea to recreate what James has done on his instagram, and then latter share it with others who want to study nodeeditor and nodes ; but now I think it would be a very hard task! Maybe only james can share his works!
What do u think?
Also, I tried to put the parametric formula for "trefoil knot" in Mathpoints node but it still doesn't give me what I want (Jame's Instagram post). (check the attached node file)
8916.31 In reply to 8916.28
I used Concat node but I cannot even get it connected to the following nodes: Math & MathPts.
8916.32 In reply to 8916.31
Right-click on the node, a menu will appear, choose what you need.
8916.33 In reply to 8916.30
Psygorn, James first shared his works, but then deleted them.
Max was also available at first, now the site is not working.
I think we should go our own way, but it will end sometime.
If you have the desire and the time, do it.
8916.34 In reply to 8916.33
I have the desire, but I don't have the knowledge and skills!
Show messages:  1-14  15-34  35-47
