Loft then boolean weirdness
All  1-5  6
8914.6
Hi There
I think also that because the inner surface that you boolean out shares the same surface as the outer you sometimes get a conflict.
If you move the inner profiles .1 mm outside of the outers then you get a clean cut as its not trying to cut a surface from a surface on the ends.
Also you get a better result if the inner and outer curves have a similar number of control points, also Offset can throw up some confused curves with way too many control points , I often rebuild them to simplify it.
You can also sweep the inside curves longer than the outer solid to cut with
cheers
shayne
EDITED: 25 Apr 2018 by SHAYNO
Size: 38.1 KB, Downloaded: 63 times, Dimensions: 800x600px
Show messages: All  1-5  6
