[Help]Simple Glass + Water Howto![Help]
 1-18  19-27
891.19 In reply to 891.18
Maybe something like this :)
But all that is just a suggestion :)
EDITED: 4 Sep 2007 by PILOU
891.20 In reply to 891.19
I see - but that UI would be very specific to just the sweep command...
Would it make sense for only sweep to have this kind of time report in it and not any other functions?
891.21 In reply to 891.20
For all functions of course :)
891.22 In reply to 891.21
The UI that you show there is only part of the Sweep options dialog - other commands don't have a "Scaling rail" button.
891.23 In reply to 891.22
< other commands don't have a "Scaling rail" button
But all functions have a dialog box where is writed "Done" or "Cancel"
so there is always somewhere a little place for input the timer for "complex functions" :)
EDITED: 5 Sep 2007 by PILOU
891.24 In reply to 891.23
Hi Pilou, there are some places where that won't work.
For example when the boolean commands finish, there aren't any options to adjust, so the "Done" and "Cancel" buttons are removed immediately after the boolean finishes...
891.25 In reply to 891.24
< so the "Done" and "Cancel" buttons are removed immediately after the boolean finishes...
In this case :)
891.26 In reply to 891.25
Hi Pilou, at the moment there is a place there. But in version 2.0 when you are not in a command, that currently blank area will probably be filled with a panel that shows and allows you to edit the properties of the selected object.
Anything that goes in that spot needs to be of a pretty high usefulness for general operation of the program.
I'm sorry - the timer just does not seem to be useful in enough situations to place it in such a prominent place in the UI... Most of the time it would just say "2 seconds elapsed" - it would only be helpful in some very particular and somewhat unusual circumstances.
I've got to be very careful not to add a lot of UI widgets that are only useful in unusual circumstances, because that is how things get cluttered and harder to use!
But one thing I want to add at some point in the future is a mini text log output area where I can write stuff like error messages and additional information, maybe once I figure out where that will go I could add an "elapsed time" message to that output.
891.27 In reply to 891.26
No problem, it's not vital essential crucial:)
Show messages:  1-18  19-27
