Select similar edge/face?
 1-2  3-22  23-29
8905.3 In reply to 8905.2
Hi Michael! Thanks for very quick replay!
I know all about Moi selection methods but i have noticed that even with all the nice Moi selection options i still often do click-by-click arrays of edges/faces to, for example, bevel. It is just a tedious and time consuming process i thought that it would be very handy if some similar scirpt is out there or possible to do.
No worries, it's no big deal. ;)
You have the inverse!
http://moi3d.com/forum/index.php?webtag=MOI Random selection! ;)
My Moi French Site My Gallery
8905.5 In reply to 8905.3
Hi klaudio, can you post an example model?
In the same order of idea : a Point is drawn on something and snapped (an edge, a surface, an object)
Copy this point anywhere any time you want : if it's snapping to something (edge, surface, object) this "something" will be selected!
So if you make an circular array with it, (here 3) these faces will be selected!
Does it easily possible ? (Of course all edges, surfaces, object are Separated, Trimed... etc)
Advantage: no need of "something similar" (can be (first post) but not necessary) ! ;)
EDITED: 13 Jun 2018 by PILOU
8905.7 In reply to 8905.6
Hi Pilou, it doesn't seem like it would be very easy to set that up.
8905.8 In reply to 8905.7
I have tried ...and whished that a function Connected to something --> Selected was existing in the script tools box functions! :)
There is Move Slice to Point(s), Scale Array with Points ... :) A Point(s) Select could be existed... :)
But I am not in the Box! :D
EDITED: 8 Apr 2018 by PILOU
8905.9 In reply to 8905.8
Hi Pilou, there is something for things which are actually topologically connected:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.4
But a point that's a separate object that just happens to be located on an object is not the same thing as being actually connected to it.
8905.10 In reply to 8905.9
Yes i have this tricky script Expand / Skrink selection by Max on my site! :)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Very useful with Subdivided Object for crazzy forms! :)
8905.11 In reply to 8905.8
I do think it's possible to have that - but you asked if it was _easily_ possible.
8905.12 In reply to 8905.11
If not easy possible...maybe for V5 :)
8905.13
I do double the request of Klaudio. It is a need I do meet very often. I am accustomed to use it in my favorite polygon modeler, Wings 3D, and I know well how much useful it is. Having a way of selecting all the edges -or faces- of an object, using a 'select similar' command, would be very helpful. You want to bevel many similar edges and you have to select them one by one. It is a little bit tedious. Not a so big problem but it has to be mentioned.
8905.14 In reply to 8905.13
Hi Dimitri, can you please post an example model where you were running into this problem?
Hello everyone!
If we talk only about EDGES/Curves (and not faces or other things), I think that maybe you could be interested in using my custom command "FilterCurvesByLength"
I use it a lot when I want to select similar edges/curves in one shot!
Here's the demo video : http://take.ms/mDpcW
And here's the link to the original post, please read it carefully :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8608.20
And here's an example screen capture :
Enjoy ;)
8905.16 In reply to 8905.5
re Michael:
It's just a example model to showcase the feature, simple cylinder and then created circle and use Circular Array - boolean difference - done.
re mkdm:
> If we talk only about EDGES/Curves (and not faces or other things), I think that maybe you could be interested in using my custom command "FilterCurvesByLength"...
Interesting! I'll give it a try and see how it goes a bit later. The edges selection is indeed needed in like 99% of the time so faces selection is not that important.
I am curious, does this script has a feature where you can select one edge (or few continuous edges) and then in the script to get it's length + select all other edges with the same length? It would be handy to have that option to get it like that instead of tweaking min and max slider until you get the right edge. Do you know what i mean?
You have also these scripts by Michael
script: /* Select by Lenght */ var min = 1.0, max = 5.0; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
You can input your owns values!
script: /* Select Biggest */ var curves = moi.geometryDatabase.getObjects().getCurves(); var maxlen = -1; var maxcrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen> maxlen ) { maxlen = thislen; maxcrv = crv; } } if ( maxcrv != null ) maxcrv.selected = true;
script: /* Select Smaller*/ var curves = moi.geometryDatabase.getObjects().getCurves(); var minlen = 1e100; var mincrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen < minlen ) { minlen = thislen; mincrv = crv; } } if ( mincrv != null ) mincrv.selected = true;
8905.18 In reply to 8905.16
Hello Klaudio!
@You : "...I am curious, does this script has a feature where you can select one edge (or few continuous edges) and then in the script to get it's length + select all other edges with the same length? It would be handy to have that option to get it like that instead of tweaking min and max slider until you get the right edge. Do you know what i mean?"
Yes, I mean.
No, actually there isn't a feature like that because I've stopped the developing of that plugin some times ago because I'm very busy at work and I can't put again my hands on it.
But...maybe also the actual implementation of my custom command can easily allow you to achieve what you want to do.
Follow this little video tutorial based on your model : http://take.ms/BN9QV
I often use the that trick. I hope the it can be useful also for you.
Ciao!
8905.19 In reply to 8905.16
Hi klaudio, thanks for posting the example model. So for many cases you can use the already existing function of window selection to select many edges in one action, you aren't limited to selecting edges one by one by clicking only.
The way it works is you select just one edge to start with - once one edge or face is selected then a window select after that will similarly target edges or faces. Also window selection works in 2 different ways depending on whether you drag towards the left or the right. Dragging towards the left will target things that cross any part of the window while starting on the left and dragging towards the right will only target things totally contained inside of it.
Here's how it works using your file:
Hide, Lock and Inverse Selection can be also a very big help!
8905.21 In reply to 8905.20
You can also hold down Ctrl while doing a window selection to do a deselection window instead of selection window. One other trick is if your screen is all filled up so it's hard to find a blank area to start the window you can hold down Shift+Ctrl, that will force window selection to happen anywhere and disable the regular click selection.
8905.22
Michael I do think that Marco's script can be very useful as to the thing that I did mention (I learned about its existence just now) but, still, I think that a very simple 'select same' command would be very helpful: you just select a curve, an edge, a face or an object and then click 'select same' and, there, you have selected all the same curves, edges, faces or objects in the working space!
Below I am putting a simple explanatory image. What we do in such a case when we do want to select all the similar faces -as the selected one- on such an object (other than selecting them one by one)?
EDITED: 10 Apr 2018 by DIMITRI
Show messages:  1-2  3-22  23-29
