Spring shapes
 1-6  7-24
8904.7 In reply to 8904.4
You guys amaze me with your scripts! Tried the script...woooow. So easy, I feel like I'm cheating.
Thank you!
8904.8
Hi guys,
Tried out your suggestions, worked perfectly!
Combined moving the control points to make the "step" portion with, array and sweep.
Thanks so much for your help!
Mat
And you can render with the free real time Simlab Composer Lite (Max 1920*1080)
http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
Export from Moi in OBJ format
Have fun Sculpting Rendering!
8904.10 In reply to 8904.9
Thanks for the suggestion. I'll have to try it.
Using Keyshot for renderings. Keyshot doesn't like Moi for some reason...so I have to save the MOI file in Rhino....then put it into Keyshot.
Thx.
M
8904.11 In reply to 8904.10
Hi mat, I think Keyshot may only read Rhino display information from .3dm files, so using .3dm format may not work.
But what should work is to write out from MoI using .obj format with the "Output: Quads & Triangles" option in the meshing options dialog box. Then open that .obj file in Keyshot.
8904.12 In reply to 8904.11
Thanks for the tip. Since I bounce between MOI and Rhino, I don't mind to save in 3dm.
I need to call Keyshot and request they update the software for MOI, ha.
Thx,
Mat
8904.13 In reply to 8904.10
"Keyshot doesn't like Moi for some reason... "
HI,
I work with Moi and Keyshot and import directly 3dm files in it.
No need to save the file in Rhino.
8904.14 In reply to 8904.13
Maybe this changed with some newer version of Keyshot, I can't remember the details.
Keyshot Pro, (Version 6 or 7), will directly import NURBS files, including MoI NURBS files.
It is my limited understanding that the less expensive Keyshot HD does not import NURBs..., but does import meshes.
(I purchased V6 some time ago, but never upgraded to v7)
8904.16 In reply to 8904.15
Correct - I have Keyshot Pro ver 7 and it imports 3DM files from MoI directly.
My spring below:
8904.17
Hey guys,
I'm using Keyshot Pro 7.2.135.
Just tried a fresh MOI test file. No go. I get a window with a red stop sign "file.3dm did not appear to contain 3D geometry. Inside Rhino, please select View/Shade prior to saving it."
So I always have to re-save my MOI 3dm in Rhino...then open in KS.
Is there some setting somewhere in MOI or Keyshot? Sure would love to get MOI files to open in KS.
Thx,
Mat
8904.18 In reply to 8904.17
In the Import panel > Geometry
Have you check Import Nurbs Data ?
8904.19 In reply to 8904.18
Success!
Thanks Finema!
8904.20 In reply to 8904.19
great !
Yeah - I don't understand why Keyshot can't turn on their "Nurbs" flag automatically when importing a file with a 3DM extension.
Can a 3DM file be anything other than Nurbs?
8904.22 In reply to 8904.21
"I don't understand why Keyshot can't turn on their "Nurbs" flag automatically when importing a file with a 3DM extension."
because with Rhino 3dm files you can choose in keyshot to import the geometry in Nurbs or not.
8904.23 In reply to 8904.21
Hi Ed.
@You : "...Yeah - I don't understand why Keyshot can't turn on their "Nurbs" flag automatically when importing a file with a 3DM extension..."
Because, as you can see in this screen shot, a 3DM file in Rhino can contain both Nurbs and Mesh objects ;)
Marco (mkdm)
Got it - Thanks :)
Show messages:  1-6  7-24
