Alternative UI layout
 1-16  17-27
8903.17 In reply to 8903.16
Hello Michael, hello immortalx,
in my current CustomUI I already have these buttons and they work. The question was rather: "How do I get the buttons (included in the version of Max) into the UI of immortalx"?
My knowledge of HTML is not exactly record-breaking.
Many thanks to you both and also to Max for your wonderful development work.
-moritz
8903.18 In reply to 8903.17
Hi moritz, well you'll need to do something like examine the differences between the standard UI and Max's custom ui, then apply the same modification to immortalx's UI.
Please note that all these custom UI setups are not a standard part of MoI and aren't something that I'm focused on supporting myself.
I can try to give you some hints to help you figure it out, maybe a first step would be if you could post more detailed information like which version of MoI you're trying to do this to and which version of Max's CustomUI you are using and what operating system you're running on.
8903.19
I just want to emphasize and support what Michael has just mentioned.
It's extremely difficult for a developer to support non standard customization to his/her application. We should all be thankful in the first place, that we are actually able to do that, and everyone trying these custom modifications should be well aware that they can break the application's functionality.
With that said (and although I've no previous HTML knowledge, just general programming background) you are welcome to ask me anything for this custom ui and I'll do my best (if I can) to make it happen :)
8903.20 In reply to 8903.18
Hello Michael,
I am using Max' CustomUI.2.0.beta1 with MoI V4 and a MacPro 5.1 with OS X 10.10.5
- moritz
8903.21 In reply to 8903.20
Hi moritz, so if I remember right Max's new CustomUI 2.0 for MoI v4 uses this element that is in the default MoI v4 CommandBar.htm as the target for where to place the added buttons:
            <span id="CommandBarCustomUI">
            </span>
This element appears to be missing in this alternative UI. If you add it in that may solve it.
But also I would think you would see an error message pop up when the CustomUI startup script tried to do something to this element but it wasn't there, however you didn't mention any error message being displayed?
8903.22 In reply to 8903.19
Hi immortalx,
In addition to the shortcut key editor, everything else is perfect. The shortcut key editor background color and scroll bar can be modified?
8903.23 In reply to 8903.22
Hi Yuan, sorry in MoI V3 the shortcut key editor is a non-HTML custom control and there isn't any way to modify its colors.
This is solved in V4 - in MoI v4 the custom control is removed and the shortcut key editor is HTML based and can have colors modified same as other UI.
8903.24 In reply to 8903.21
Hello Michael,
thanks for pointing that out. The program runs so far, but I get this error message (error_message.png):
@immortalx:
Hello immortalx,
I miss the dimensions of selected objects. Is that correct?
(UI immortalx.png vs. default_UI.png)
- moritz
Size: 77.5 KB, Downloaded: 30 times, Dimensions: 645x394px
Size: 73.4 KB, Downloaded: 19 times, Dimensions: 750x276px
Size: 104.5 KB, Downloaded: 32 times, Dimensions: 787x428px
8903.25 In reply to 8903.24
Hi Moritz, that error message looks like it's from the startup script here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.8
The problem you're running into is the one I described later in the thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.12
You'll need to remove that file from your app data startup directory.
Please note that all the problems you are describing here are from interactions between extensions that are not part of the regular MoI install and are not supported by myself directly.
8903.26 In reply to 8903.25
Hello Michael,
thanks for the help.
I'd better leave the MoI V4 as it is for now.
But what I really miss - compared to the V 3.1 - are the little helpers for better orientation (see photos). Will they reappear in the final version?
- moritz
Size: 95 KB, Downloaded: 32 times, Dimensions: 527x413px
Size: 107 KB, Downloaded: 30 times, Dimensions: 573x423px
Size: 113.6 KB, Downloaded: 43 times, Dimensions: 580x427px
8903.27 In reply to 8903.26
Hi moritz, yup those text labels will be coming back for v4 soon.
Show messages:  1-16  17-27
