A Script to export to URDF
All  1  2-10
8895.2 In reply to 8895.1
Hi Jeff, MoI doesn't store a local origin for every object, so an object in MoI does not really have any position or orientation stored for it, so that might be difficult to do. It might not be feasible until the time that MoI supports the concept of "instances" which will have that type of information stored.
There isn't much information about scripting available, what is available is here: http://moi3d.com/wiki/scripting .
You might check out the CutList script as an example of gathering object names and writing out a text file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7759.2
8895.3 In reply to 8895.2
hmm....
I think I can solve the position by:
creating a tiny "node" object like a small cube as a subobject for each part
then can I get the position of the bounding box of the node.
but for orientation, I'd need to know the rotation of the node.
I thought maybe a cube (as a primitive) would have orientation.
But playing with "Separate" on a cube, I see that it's composed as 6 planes to enclose a solid.
So when we rotate, moi just transforms the vertices?
Jeff.
8895.4 In reply to 8895.3
Hi Jeff,
Yes, that's correct.
8895.5 In reply to 8895.3
But if you are able to attach some additional node objects to each main object instead of doing a cube if you did a 3 orthogonal lines one for x, one for y, one for z, that might be workable.
8895.6 In reply to 8895.5
For importing into Unity, I think it ignores points and lines.
Only meshes are imported. So maybe three triangles in the form of a corner to represent the axes.
Jeff.
8895.8 In reply to 8895.6
Hi Jeff, sorry I'm not understanding the part about importing into Unity - I thought you needed to write the rotation information into an XML file.
8895.9 In reply to 8895.8
sorry for the confusion - I have URDF which I use for the physics engine import, but
I also to import robot models into Unity using URDF for easy visualization and PBR rendering.
(you can see some examples at my website www.spryrobotics.com).
Jeff.
Show messages: All  1  2-10
