Off-topic — ZBrush 2018
 1-15  16-33
BTW: regarding bas reliefs with ZBrush....
i already ask a while ago the author, #AskZbrush and asked also
at CGTalk, but nobody could explain to me how to do that properly
with ZBrush... (like the dragon model)
http://www.zbrushcentral.com/showthread.php?185811-Bas-Relief-amp-Other-Works
8884.17 In reply to 8884.16
Hi Stefan,
I would first create an alpha texture from the 3D model, then stamp the alpha onto the 3D shape you want it to be on, in a very high polygon resolution, to maintain all detail.
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
8884.18
I've been playing with Sculptris Pro dynamic tesselation mode this morning, here's my first freestyle sculpture. No reference used, I've just been playing around. Sculptris Pro works very pleasantly.
Regards,
— Metin
The Top raw gallery of Zbrush is an amazing collection of true Master pieces!
http://www.zbrushcentral.com/zbc-top-row-gallery.php
Over 15 years and alas not all old pictures are not more obtainable! :(
The dancer by Xioa Ming
Hi Metin,
yes, alphas could be a gould start, depending how they look like... because they usually
give also the straight extrusions at the models silhouette.
Nice model Metin, looks like you have fun with Sculptris Pro! :-)
8884.21 In reply to 8884.20
Thanks Stefan!
For complex relief ZBrush offers Vector Displacement Brushes, which include overlapping:
http://docs.pixologic.com/user-guide/3d-modeling/exporting-your-model/vector-displacement-maps/
Regards,
— Metin
Hi Metin,
i think this is also not good, because you need already a bas relief in order to convert
it to Vector Displacement...
Anyways, thanks for your suggestions. Maybe one day someone can lift the secret
described in the ZBrush thread, i have posted. ;-)
8884.23 In reply to 8884.22
Can you describe in detail your problem about the "Dragon bas relief" and what do you want to know!
I ask that to my friend who works at Pixologic! ;)
It's not pure sculpting ?
EDITED: 2 Apr 2018 by PILOU
thanks for your help, much appreciated!
The author says that he used ZProject brush to get the bas relief, but i wonder how he
does this with ZProject, because the dragon bas relief is pretty flat, compared to the
original model. When one uses ZProject he usually projects the mesh on a plane with
the same height and not so flat. Someone on Twitter told me to use the settings -100
but that had no impact when i tried it. There must be some easy? step, which i am not
aware of.
Also i don't understand how he managed to ZProject the top sphere with the two stripes
on the tail, which is more off Z then the dragon, so that it sits perfectly on the tail, without
extrusions.
8884.25 In reply to 8884.24
I believe its necessary to modify the model to provide a workable bas-relief. Some models may work with little or no modification but in general I think it is not a push button task to go from model to relief.
8884.26 In reply to 8884.24
Send it! Wait and see! :)
My Moi French Site My Gallery
@chris: The author mentioned only ZProject and did not explain how
he did it with ZProject.
@Pilou: Thanks a lot!
8884.28 In reply to 8884.27
@Stefan
My friend is overwhelmed with work so just some speed advices! ;)
Be careful when you make bas relief, in general you prepare the model that will serve as a support for the projection accordingly, i.e. be careful that it is as much as possible in a single plane.
It is not impossible that the artist applied some transformations, see dynameshed his model just before making his projection.
Moreover I admit that I will tend to make a projection of SubTool and eventually use the brush ZProject to eventually make touch-ups.
It should not be forgotten that ZProject also works with ALT depending on the position of the model and the projection...
Hope this can help a few...
thanks for the informations from you friend!
It looks like from his desrciption that severeal steps are involved, as Chris mentioned too.
So i have to see if i can come up with something in the future, when using ZBrush.
EDITED: 4 Apr 2018 by PILOU
Intensive use of the "ZModeler" (another world of mechanical sculpting )
: use the actual rectangular menu is some cerebral painfull - seems will be more fun if it's will be "radial" :) ...
https://pixelprotest.com/projects/45-days-of-zbrush/
EDITED: 6 Apr 2018 by PILOU
Pretty awesome!
Thanks for posting this, Pilou!
8884.33
That's a very nice update, the snake brush with Sculptris mode is quite impressive.
Marc
Show messages:  1-15  16-33
