Guitar neck and arch top methods
 1-13  …  54-73  74-93  94-113  114-133  134-153  …  194-206
8883.94 In reply to 8883.93
Great work Neil!
8883.95 In reply to 8883.93
Hi Neil,
I have managed to get a good result using a simple network, trim and blend into head.
I would like to try it on some different heads before posting the process.
So if you have any curve drawings of heads you can share can you post them to me.
Barry
8883.96 In reply to 8883.93
Wonderful job!!!! Congratulation!!!
8883.97 In reply to 8883.95
Hey that looks fantastic Barry - really awesome. Have a couple been working on that will send - also a .dxf of a LP for something different. Looking forward to seeing what you do with the other files too. - Neil
8883.98 In reply to 8883.97
Hi Neil,
got the files will look at them Monday as I'm away the weekend.
Barry
8883.99 In reply to 8883.95
Lookin' good Barry!
8883.100 In reply to 8883.93
Nice Neil! Hand wound pickups too, sweet.
M
8883.101 In reply to 8883.26
Great advice Barry - thanks much!
8883.102 In reply to 8883.30
Hi - sorry I didn't reply earlier. Yes I own two CNC machines. As you mentioned it seems the best neck transitions are done with filleting, blending, networking - and Boolean operations .. . unfortunately I have a long ways to go until I'm past the "learn your basics" stage - but its fun anyway!. Nice to know there is another hand builder around here you can appreciate what's involved. If you ever want to mill something let me know. Thanks a lot for your input.
8883.103 In reply to 8883.101
Hi Neil,
here is the method I have been using with network & blend.
I'm still looking at lespaul head it may require a different method.
Hope this helps.
Barry
8883.104 In reply to 8883.103
Wow - excellent - that is really clever - and looks fantastic. Have to get to work on that. Many thanks Barry! Trimming spheres that is so cool. I'll bet I wont be able to duplicate your work. I'm still having trouble reliably repeating trim and blend. :)
EDITED: 24 Apr 2018 by VEGASGUITARS
8883.105
Hi Neil
I was struggling with the same challenge. I came up with this.
8883.106 In reply to 8883.105
Hello jopo,
That looks excellent - very nice transition! Thanks for sharing. Well done - can't wait to try that.
8883.107 In reply to 8883.80
Here's a neck using Barry's trim and blend method and basic networking - all basic commands. Everything on this one checks out - so I feel I can move on to Barry's other method of using trimming spheres. And jopos networking and trimming example.
EDITED: 22 May 2018 by VEGASGUITARS
8883.108 In reply to 8883.105
Thanks jopo,
I tried your method but obviously need to work on it - not sure how you're drawing the lines between the spliced arc and the headstock back - but the way you draw makes the network very smooth.
EDITED: 26 Dec 2020 by VEGASGUITARS
8883.109 In reply to 8883.6
3d objects on cnc are machined using a ball-ended bit.
Similar to a topographical map, tool paths are mapped over the undulating surface of the 3d object. The finishing quality is achieved by placing these tool paths as close to each other as to create 90 percent overlap of the tool, which means it takes a long time.
Whenever profiling bits can be used, they are great because they are fast and require minimal sanding. The profile of something like a guitar neck is not consistent the way a profile bit is, unfortunately, leaving no choice but to go for 3d machining.
I hope this helps?
I use cnc to produce artwork and architectural elements - this is why I am learning MOI.
Cheers!
8883.110 In reply to 8883.109
I use different bits for roughing and finishing - but always a ball end for finishing.
8883.111 In reply to 8883.108
could you pleas mark the lines you mean.
8883.112 In reply to 8883.111
Hello Jopo,
Please show me how you draw these highlighted (yellow) lines so that you end up with a rounded surface - when I try it leaves a crease.
8883.113 In reply to 8883.112
Hi Neil,
If you can please post the 3DM model file with your creased result in it, that could make it easier for someone to figure out what went wrong when you tried it.
Show messages:  1-13  …  34-53  54-73  74-93  94-113  114-133  134-153  154-173  …  194-206
