Guitar neck and arch top methods
 1-5  …  46-65  66-85  86-105  106-125  126-145  …  206
8883.86 In reply to 8883.79
Here is my attempt at the fillet method - started from scratch with this and used a new headstock design which kind of screwed up the mating of the lofted neck and headstock - but it's solid and good for a first try. Thanks Barry - will keep practicing this method - very clever indeed.
EDITED: 25 May 2018 by VEGASGUITARS
Size: 1.3 MB, Downloaded: 318 times, Dimensions: 1920x1080px
8883.87 In reply to 8883.86
Hello VEGASGUITARS.
Thanks for sharing!
I don't know which method did you use to build the model but that are issues as you can see :
Regards.
8883.88 In reply to 8883.87
Thanks for pointing out that mistake.
EDITED: 2 May 2018 by VEGASGUITARS
8883.89 In reply to 8883.88
Hi Neil,
Try moving the seam.
Barry
8883.90 In reply to 8883.89
How's this one Barry? :)
8883.91 In reply to 8883.90
Hi Neil,
looks good your on the way.
Barry
8883.92 In reply to 8883.91
Barry, Yay! Thanks very much for your patience and great advice. I really like the way you model - very clever ideas! There are so many things you can do with Boolean commands - very cool stuff.
N
8883.93 In reply to 8883.92
Here's a guitar I just finished for a customer in Phoenix - hand made from scratch under one roof by a crotchety, snaggle tooth, good ball. BTW I also hand wind all our pickups too. :)
Size: 88.5 KB, Downloaded: 253 times, Dimensions: 960x903px
8883.94 In reply to 8883.93
Great work Neil!
8883.95 In reply to 8883.93
Hi Neil,
I have managed to get a good result using a simple network, trim and blend into head.
I would like to try it on some different heads before posting the process.
So if you have any curve drawings of heads you can share can you post them to me.
Barry
8883.96 In reply to 8883.93
Wonderful job!!!! Congratulation!!!
8883.97 In reply to 8883.95
Hey that looks fantastic Barry - really awesome. Have a couple been working on that will send - also a .dxf of a LP for something different. Looking forward to seeing what you do with the other files too. - Neil
8883.98 In reply to 8883.97
Hi Neil,
got the files will look at them Monday as I'm away the weekend.
Barry
8883.99 In reply to 8883.95
Lookin' good Barry!
8883.100 In reply to 8883.93
Nice Neil! Hand wound pickups too, sweet.
M
8883.101 In reply to 8883.26
Great advice Barry - thanks much!
8883.102 In reply to 8883.30
Hi - sorry I didn't reply earlier. Yes I own two CNC machines. As you mentioned it seems the best neck transitions are done with filleting, blending, networking - and Boolean operations .. . unfortunately I have a long ways to go until I'm past the "learn your basics" stage - but its fun anyway!. Nice to know there is another hand builder around here you can appreciate what's involved. If you ever want to mill something let me know. Thanks a lot for your input.
8883.103 In reply to 8883.101
Hi Neil,
here is the method I have been using with network & blend.
I'm still looking at lespaul head it may require a different method.
Hope this helps.
Barry
8883.104 In reply to 8883.103
Wow - excellent - that is really clever - and looks fantastic. Have to get to work on that. Many thanks Barry! Trimming spheres that is so cool. I'll bet I wont be able to duplicate your work. I'm still having trouble reliably repeating trim and blend. :)
EDITED: 24 Apr 2018 by VEGASGUITARS
8883.105
Hi Neil
I was struggling with the same challenge. I came up with this.
Show messages:  1-5  …  26-45  46-65  66-85  86-105  106-125  126-145  146-165  …  206
