Guitar neck and arch top methods
 1  2-21  22-41  42-61  62-81  82-101  …  202-206
8883.42 In reply to 8883.33
Mat10x do you have any examples of how you do necks? Thanks, N
Neil Smith
Vegas Guitars Custom Shop
http://vegasguitars.com
8883.43 In reply to 8883.42
Hi Neil,
I don't have a neck example but I think the attached models I built may illustrate the use of "Network".
I use "curve network surface" or "network" all time for surfaces that need to come together under very specific dimensions, with clean transitions from one surface to another. Automotive design, lots of surface transitions, same idea.
The volute is a good example. Couple surfaces coming together at that one intersection. The English guy in the YouTube video also used "Curve Network Surface" (as he used Rhino 3D) or "Network" (in MOI) for his volute.
As a guitar player and Industrial Designer...I'd prefer to specify the volute surface dimensions rather then just "blend" them together.
Just my .02 cents.
Hope that helps!
Mat
8883.44 In reply to 8883.28
Some of your stuff looking dan electro esq!!!
Nice!
8883.45 In reply to 8883.43
Hey Matt!
Thanks for the reply - the problem I have with networking is getting things solid. Seems my necks are always hollow when I use the networking command - see attached. Also - what do you do about seams or lines between the pieces you network? Thanks for the suggestion - would like to get better at this.
EDITED: 21 May 2018 by VEGASGUITARS
8883.46 In reply to 8883.44
Dan Electro? Really? I don't see that at all. But if it's a compliment I'll take it!! :)
Neil Smith
8883.47 In reply to 8883.43
Wow those models are awesome Matt! How do you do that without getting seams or gaps? Practice right! :)
Neil Smith
8883.48 In reply to 8883.45
Hey Neil,
Your heel surfaces are not aligned with each other. Double check the alignment of your curves. All surfaces must be aligned to each with no gaps...to create what's called a "water tight" model...a true solid.
Hope that helps!
Mat
8883.49 In reply to 8883.47
Yep, lots of practice...just like learning to play the guitar. ;) Always something new to learn in MOI...or guitar!
The forum here is a great resource. The guys here are incredibly helpful.
M
8883.50 In reply to 8883.46
Yeah Neil,
The longhorn and a couple of the other full bodied ones...
I knew Nat. it WAS meant as a good comment.
8883.51 In reply to 8883.50
To Burrman - Thank you sir!! Much appreciated.
8883.52 In reply to 8883.48
Thank you Matt - will work on tightening things up. There are several snap to settings which is best for networking? What I mean is do you have Straight Snap, Grid Snap and Object snap all on or do you use only one or two?
8883.53 In reply to 8883.48
Hello Mat10x,
Here is the CNC I just finished building - haven't wired it up yet hope to do that this weekend. It's a real tank. Also attached a few more rock oriented guitars I built over the years - sorry about the quality on some of the pictures and more importantly many thanks for your help and suggestions!
EDITED: 22 May 2018 by VEGASGUITARS
8883.54 In reply to 8883.53
Wow, that full mahogany one is awesome !
8883.55 In reply to 8883.52
Hey Neil,
Yeah post up your neck when you have it rebuilt. Love to see how it turns out.
The 3 "snaps"...I use all 3...but for different needs. Make a simple cube or basic curves to build off of and play with all 3 snaps to see what they do and when you need them.
Snaps are not just for "network"...they're for building in general. Must have tools for keeping things aligned and properly positioned as you build.
M
8883.56 In reply to 8883.53
Hey super nice Neil!
First and second image? Mahogany with Macassar fretboard? Love the contoured heel. No contouring on backside of the lower horn to match?
Not sure how I feel about the drop headstock though. Why no tilt back or just a straight headstock?
Might have to call you about doing a custom. Love to design a body, neck, headstock...and have some body route it for me.
Lookin' good!
M
Message 8883.57 deleted 10 Aug 2021 by VEGASGUITARS
8883.58 In reply to 8883.57
Just finished building my second CNC machine tonight - here's a first run "air cut" . . . had no issues - ran a 45 minute cycle without a hitch.
EDITED: 11 Jan 2021 by VEGASGUITARS
8883.59 In reply to 8883.58
Hi Neil,
I have been playing with the network method and here's my latest attempt
using your drawing as a start.
I have done some trimming and blending to remove some of the crease lines
not sure if that's the best way but it looks Ok to me.
Have you looked at Zarkow video http://moi3d.com/forum/index.php?webtag=MOI&msg=8845.5
I tried it on the neck network and looked promising.
Barry
8883.60 In reply to 8883.59
Hi Barry-H,
Man that looks terrific!! Will take a look at that video.
Thanks so much for the help - greatly appreciated.
N
Neil Smith
8883.61 In reply to 8883.50
So BurrMan - what was Nat Daniels like? Seems like a brilliant business person - I had a couple of his double cutaways as a kid. They were really fun guitars - and played great.
Neil Smith
Show messages:  1  2-21  22-41  42-61  62-81  82-101  102-121  …  202-206
