Guitar neck and arch top methods
 1-2  …  143-162  163-182  183-202  203-206
8883.183 In reply to 8883.182
Fantastic - thanks Michael! This method looks much better than the patchwork. That's an excellent start to getting a handle on this. Have no experience yet with subD (although did download Rocket as you suggested). Thanks very much for the tips to get rolling. Here is another arch top from the same guy - not really crazy about this arch top - it's a bit too flat on the top. Tried to attach the file - but am out of space. If anyone want's it let me know. Really like the dimensions in V4.
EDITED: 26 Dec 2020 by VEGASGUITARS
Size: 120.7 KB, Downloaded: 94 times, Dimensions: 1459x972px
8883.184 In reply to 8883.183
Hi Neil,
Well we'll probably arrive at some patch-by-patch filling in yet when coming inwards from the rounded tips.
But if helps if you can use as few surfaces as possible with extended areas that are trimmed rather than building every surface directly to some initial curve framework.
The other thing that's good about having a smaller number of surfaces is you can adjust the shape easier like with the steps above you can tweak the loft profile curves to control some subtle curving. When things are diced up into smaller pieces being filled in it becomes difficult to make a broad shape adjustment.
8883.185 In reply to 8883.184
Here's a method Barry came up with (using one of my flat top models) that uses the ideas Michael shared . . . the files Barry sent me are below and include the model and an animated .gif that shows how to do it. This is Barry's work.
EDITED: 21 Feb 2021 by VEGASGUITARS
8883.186 In reply to 8883.185
Thanks Barry - clever, interesting and fun method - took a few tries - but finally got it. Thank you for sharing. As you can see I have a couple bulges on either side - the original you made did not have them - not sure where I went wrong yet. Also, putting finishes this week on the two arch tops I milled from your models last year. It's fun to finally have the time to learn how you did it (recently hired a helper in the shop)! Now on to trying your methods with a different guitar from scratch - that should only take a few months if I'm lucky.
8883.187 In reply to 8883.186
Hi Neil,
if the bulges are in the blend use the sync points in the blend command this will smooth them out.
Barry
8883.188 In reply to 8883.187
Thanks Barry - will work on that!
Message 8883.189 deleted 5 Mar 2021 by VEGASGUITARS
8883.190 In reply to 8883.188
Barry - here is another result of your help with the arch tops. Many thanks again for your help! Just finished this one. Walnut top, Sapele center block with Meranti wings. 25.75 scale.
EDITED: 22 Mar 2023 by VEGASGUITARS
Size: 228.8 KB, Downloaded: 103 times, Dimensions: 1586x979px
Size: 926.2 KB, Downloaded: 156 times, Dimensions: 1000x790px
Size: 821.8 KB, Downloaded: 326 times, Dimensions: 1000x630px
Size: 198.2 KB, Downloaded: 93 times, Dimensions: 1434x1013px
Size: 857 KB, Downloaded: 299 times, Dimensions: 1000x695px
Beautiful!
8883.192 In reply to 8883.190
Hi Neil,
looks great hope business as picked up after pandemic.
Barry
8883.193 In reply to 8883.191
Thanks Frenchy Pilou!
8883.194 In reply to 8883.192
Thanks Barry - things are OK. Looking to retire in the next couple years.
8883.195
I just recently built a 12 string guitar for the new guitarist in the Beach Boys - it was mostly done in 2D except for the arm and tummy contours. The body was made entirely in Moi3D and milled on the CNC machine. The neck shape was cut out and then made without using the CNC.
Although the guitar is the shape of a Fender Jazz Master - it is much different. The guitarist asked me for a guitar that looks like a Fender Jazzmaster. However, the original Beach Boys recordings feature 12 string guitars that were of a shorter scale length than a Jazzmaster and with humbucking pickups. So this guitar is a shorter scale length and features humbucking pickups - that look like Jazz Master pickups. The bridge is chrome over brass with strings through and all 12 of the saddles adjust completely so the guitar is perfectly in tune. The neck wood is quartered maple and the body is lightweight alder. When the wife and I went to see them in Chandler, AZ last year - they took us back stage to meet Mike Love and Bruce Johnston - and everybody complemented me on the sound of the guitar.
In the picture of people (taken backstage in Chandler, AZ) - John Wedemeyer (guitarist for the Beach Boys), my wife Susi, me, Mike Love, Faye Wiggins and Don Wiggins (head of support services at Fender).
Not a great video but here is a clip of the 12 string live in Carolina: https://youtu.be/kHP_4BrV7GE?feature=shared
I would like to thank everyone that helped me along the way learning Moi3D - I still have a lot to learn and look forward to spending some more time here. Again, many thanks for the advice and patience.
EDITED: 23 Jan 2024 by VEGASGUITARS
Size: 313.7 KB, Downloaded: 94 times, Dimensions: 2048x1366px
Size: 116.7 KB, Downloaded: 106 times, Dimensions: 640x420px
Size: 247.5 KB, Downloaded: 72 times, Dimensions: 1920x1080px
Size: 678.8 KB, Downloaded: 65 times, Dimensions: 1600x1590px
Size: 329.2 KB, Downloaded: 67 times, Dimensions: 1640x1333px
Size: 214.9 KB, Downloaded: 185 times, Dimensions: 1500x625px
Size: 222.6 KB, Downloaded: 93 times, Dimensions: 1500x768px
8883.196 In reply to 8883.195
Really cool work Neil!
8883.197 In reply to 8883.195
Congrats VG.....
8883.198 In reply to 8883.196
Thank you Michael.
8883.199 In reply to 8883.197
Thank you BurrMan.
8883.201
Would like to make this Tele an archtop - my Moi skills are rusty (and pretty basic anyway). Any ideas?
Thanks, Neil
I've attached the file
Ignore the other parts of the body - they are for a different project (like the pickguard for example).
Just the chambered body and top (the second top is sized to allow for a binding channel).
Thanks for any ideas or help.
8883.202 In reply to 8883.201
But I am not sure of what is an archtop guitar ? :)
Show messages:  1-2  …  123-142  143-162  163-182  183-202  203-206
