Guitar neck and arch top methods
 1-20  …  121-140  141-160  161-180  181-200  201-206
8883.161 In reply to 8883.160
Great things!!
Congrats!!
8883.162 In reply to 8883.161
Thanks Marco!
8883.163
Here's the first 3D body done with the new machine - of course it will look better after finishing. Ruined a few pieces of cheap wood before getting the CAM portion correct. The neck was not cut for the contoured heel but rather a standard heel - will do the contoured one in the model shortly.
EDITED: 21 Feb 2021 by VEGASGUITARS
Size: 89.1 KB, Downloaded: 106 times, Dimensions: 1000x536px
Size: 102.5 KB, Downloaded: 107 times, Dimensions: 1000x544px
Size: 806.8 KB, Downloaded: 105 times, Dimensions: 2304x1972px
Message 8883.164 deleted 26 Jun 2020 by MICHAEL GIBSON
(removed spam)
8883.166 In reply to 8883.165
Latest guitar modeled in Moi - small body semi-hollow arch top coming soon.
8883.167 In reply to 8883.166
Beautiful!
8883.168
that's really nice. you seemed to have got the hang of MoI. you're website is nice too. i hope you have a lot of success.
Great work Neil! Something very satisfying about creating an object in MoI and bringing it to reality via CNC (and a lot of hand finishing :)
8883.170 In reply to 8883.169
Amazing work and professional photo lighting.
Mik
8883.171 In reply to 8883.170
Thanks everyone for the kind words. Can't take credit for the photo as the pictures are by a professional photographer who is also a customer.
Message 8883.172 deleted 21 Dec 2020 by MICHAEL GIBSON
Message 8883.173 deleted 10 Aug 2021 by VEGASGUITARS
8883.174 In reply to 8883.33
Great advice - thanks!
8883.175 In reply to 8883.173
Hi Neil,
> There is a guy selling tutorials on how to model guitars in Moi3D here: https://3dcncguitars.com/
That's great, I didn't know about this one! I've added a link from the MoI resources tutoriuals page.
That would easily be worth it to get very specific information on a complex area like this.
8883.176 In reply to 8883.175
Still a novice - but have learned a lot via this forum about guitar modeling. When a little further along I'd like to share, in a concise file, the tips and tricks accumulated over the years from here so that others, interested in the area, will have a solid foundation to get started with and then expand on. Certainly can save the beginner some grief.
8883.177 In reply to 8883.176
Here is an arch top made with a different program that was shared on a CNC web site - any ideas how one could do this with Moi?
8883.178 In reply to 8883.177
Hi Neil, that one seems to be built in a "patch by patch" type method where some profiles were drawn in and several surfaces probably constructed using a sweep or network type tool. One problem though with this kind of patchwork method is it's hard to get a totally smooth result. For example this area has a sharp edge:
It tends to be hard to get really good quality smoothness using this type of approach. But it is overall a pretty difficult thing to model.
Often times something organic where you would need to do a patch-by-patch approach can be handled better by sub-d modeling instead of NURBS modeling for those areas.
8883.179 In reply to 8883.177
Hi Neil, so this surface is planar so that's probably a good one to construct first from planar profile curves:
Then this area here:
I'd probably try making an extended sheet something like this using Sweep or Network:
Then that would get trimmed by a profile curve like this:
And then these areas would be done with a Construct > Blend.
You could get a large portion of it built like that but then the rounded tip protrusion like spots will be the most difficult to do well.
8883.180 In reply to 8883.177
Hi Neil, so this method would go something like this:
Planar curve here - build a surface from it using Construct > Planar.
Another planar curve on the interior like this:
Cross sections running in this direction, slightly curved:
Construct > Loft through those to make this type of extended surface:
Trim the loft with the interior curve:
Trim edges with lines to break them:
Select edges and do a Construct > Blend:
That would be a good way to start out I think getting an initial chunk of it done.
Show messages:  1-20  …  101-120  121-140  141-160  161-180  181-200  201-206
