Guitar neck and arch top methods
 1-12  13-32  33-52  53-72  …  193-206
8883.13 In reply to 8883.10
I have not been able to duplicate this correctly.
Neil Smith
Vegas Guitars Custom Shop
http://vegasguitars.com
8883.14 In reply to 8883.13
Hi Neil, please post what you have tried so far, that could help to give some ideas on what to do about it.
Just reading that you haven't been able to duplicate it doesn't give enough information about what you are seeing to be able to help any.
8883.15 In reply to 8883.13
Hi Neil,
if you select the objects as named in the browser.
1) Loft Elipse's.
2) Extrude ends tick extruded both sides.
3) Boolean join neck to bottom.
4) Fillet the join with 0.25 radii.
5) Separate Solid Head so you can trim.
6) Select the end cap of neck and delete it to allow blend.
7) Blend between neck and head (add sync points if required).
8) Select all and join surfaces to create solid.
9) Boolean Diff Boolean lines and delete unwanted pieces.
Barry
8883.16 In reply to 8883.15
Thanks Barry - with the further explanation it went great. That's so clever! Can't thank you enough for sharing your expertise.
Neil Smith
8883.17 In reply to 8883.9
Thank you Michael, very useful tip - this will come in handy.
Neil Smith
Message 8883.18 deleted 10 Aug 2021 by VEGASGUITARS
8883.19 In reply to 8883.18
Wonderful work!!
Congratulations!!
Let's play! o:)
My Moi French Site My Gallery
8883.21 In reply to 8883.20
Yeah!! ;)
8883.22
Thanks much for the positive comments, help and suggestions folks - really appreciate it!
Neil
Neil Smith
8883.23
Amazing necks Neil!
The flamed maple one is beautiful.
Marc
8883.24 In reply to 8883.23
Been working on Barry's cool method suggestion with trim and blend and while not as good as Barry's am starting to get it a bit. The problem is material missing from the front profile of the neck - in my original drawing you can see the blue lines are the front of the headstock and the red the back - when using trim and blend we use the back profile which of course doesn't include all of the neck profile - just the back of the transition. I tried using the method with the front neck shape with no luck - not sure what I'm doing wrong. The file is attached. Thanks for any and all suggestions - in the mean time will try to combine the two shapes and see what happens.
Neil Smith
EDITED: 22 May 2018 by VEGASGUITARS
8883.25 In reply to 8883.24
This one almost there - but for some reason the heel would not fillet . . . perhaps because there isn't enough height . . .
Neil Smith
8883.26 In reply to 8883.25
Hi Neil,
Fillet the profile say 0.05 to remove the 2 sharp corners then try
using the Rebuild command on the profiles it will help with the fillet and the blend.
Also if the seam line is the way you can move it by lofting instead of extruding and moving
the seam points before pressing done.
Barry
8883.27
Man those are some sweet necks! That figure on the maple is intense!
I used to build guitars too (with the help of Moi of course!). Here's some of mine:
Message 8883.28 deleted 10 Aug 2021 by VEGASGUITARS
8883.29 In reply to 8883.26
Thanks for the help Barry - your suggestions have been incredibly helpful.
Neil Smith
8883.30
Wow Neil, your work is AMAZING!
I mostly did 2D profiles which I printed to build templates (I also did all work by hand). It's been a long time, but in the few 3D models I attempted to do, transitions were done with booleans mostly, since they work so well, and were only meant for illustration, thus I had no need to be exact.
Are you planning to do CNC work?
8883.31 In reply to 8883.30
Thank you sir! Yes I own two small CNC machines and have done some milling of guitar bodies - mostly simple stuff like tele's but am hoping to do a lot more as I get better with MOI. The newest CNC machine is big enough for necks so am trying to get better in that area. Thanks for the tips. Barry has left some terrific advice using booleans - trim and blend commands in particular that have helped a lot - I just need to get better at it.
Neil Smith
8883.32 In reply to 8883.27
ImmortalX...is that blue Soloist-ish guitar have a half scalloped neck (G,B,E) from 15 to 24? I'd love to try that!
....niiiice.
Show messages:  1-12  13-32  33-52  53-72  73-92  …  193-206
