Scripts not working
All  1-2  3-7
8882.3
Thanks Micheal!!
I never knew the cmd shift . trick! You learn something everyday :-) Scripts work now and even happier knowing that will be the last time i go hunting for scripts to copy to commands folder
RE: ai export
You may recall a while back some of my requests to tidy up the points on true ellipses for export and when assigning thick and thin lines that they were not duplicates on top of initial line. No problem if you don't, you must have a lot going through your mind with MOI dev.
I can dig out screenshots if needed.
Is this something which could appear in next beta release?
Best regards
Matt
8882.4 In reply to 8882.3
Hi Matt, I'm glad you've got it working now! I do have your requests for hidden line drawing generation tuneups on my to-do list but it's not likely to be ready for the very next beta though. My focus for the next beta is to finish clearing out all the regressions from MoI v3.
8882.5
Hey Michael,
I want to use the "NutsAndBullets" script by Max Smirnov. Unfortunately it´s not working. I´m still not a computer nerd, I don´t know what I did wrong, I´m sorry!
I tried "fat lines" as well, it´s working.
I wanted to have a look at Max´s Website again, but its off..
Thanks for your help!
Best regards
Koi
Size: 50.3 KB, Downloaded: 38 times, Dimensions: 1737x413px
Size: 666.1 KB, Downloaded: 48 times, Dimensions: 2560x1555px
8882.6 In reply to 8882.5
Hi Koi, what version of MoI are you using?
You might try the script version Pilou has here:
http://moi3d.com/forum//index.php?webtag=MOI&msg=5451.99
8882.7 In reply to 8882.6
Thank you very much!
Next time I will look sharper in the old posts
cheers
Show messages: All  1-2  3-7
