Newbie learning the ins and outs of MOI
 1-4  5-24  25-44  45-64  65-78
8876.45 In reply to 8876.44
Looking good Neil!
8876.46 In reply to 8876.45
Yes it's really good !
8876.47
Here is a heel, neck transition - it is nice and smooth on the left side - so I mirrored that side - but the right side has a seam - how to fix this?
Thanks, N
EDITED: 22 May 2018 by VEGASGUITARS
8876.48 In reply to 8876.47
Hi Neil, it helps a lot if you can post the 3DM model file with the geometry in it instead of only a screenshot.
That allows for a lot more detailed analysis of what's going on.
8876.49 In reply to 8876.48
Lol - sorry Michael - the file is attached now.
8876.50 In reply to 8876.47
Hi Neil, there are 3 surfaces in that file and they look like this:
So that's clearly not a result of mirroring, there aren't separate pieces across a center mirror line like a mirror operation would create.
Maybe I'm not understanding what you mirrored though, was it the curves before building the surfaces? If you can post a file that is ready to repeat the mirror that you did that would help.
8876.51 In reply to 8876.50
Yes I apparently had several drawings combined there - which is a bad habit I need to break - constantly redrawing and not deleting - anyway - started over and used the aligning tools as Ferguson suggested and it turned out great. I'll be aligning everything from now on. :)
8876.52 In reply to 8876.51
That one is looking good Neil!
8876.53 In reply to 8876.52
Hi
Your construction lines are curious and non symetrycal.
I don't understand why you want to do something complicated for this part of the model.
See also your curve Transition 2
EDITED: 9 May 2020 by FINEMA
8876.54 In reply to 8876.53
Thanks for pointing out all my mistakes. This one is simpler and more symmetrical. I used MoI 3 and only the basic commands.
8876.55 In reply to 8876.54
it's better but there's still a little problem with that curve junction.
8876.56 In reply to 8876.55
Thanks. Maybe this is better.
8876.57 In reply to 8876.56
entire frame curve is not straight (0,0007)
see my screen shot
but perhaps it's that you want
8876.58 In reply to 8876.57
and the part is still not symmetrical
8876.59 In reply to 8876.58
Yes - thanks very much.
EDITED: 18 Jul 2018 by VEGASGUITARS
8876.60 In reply to 8876.7
Thanks for the tip - didn't apparently understand when you suggested it - found out today that I've been trying to use network where blend would be more appropriate.
8876.61 In reply to 8876.3
This is the guitar in the CAD drawings posted earlier in this thread - finished it today. It features Semi-hollow, RMC synth access, piezo out, 3 hand wound in house pickups, master volume and tone, synth volume, 5 position mag selector, mag/piezo blend pot, program up and down switch, synth/both/piezo switch, semi-hollow ash body with Mary Kay Nitro finish, flame maple neck with birds eye maple fingerboard, gold fretwire, gold hardware, locking tuners . . . and more. This guitar also features the bridge plate modification for piezo saddle wires modeled in MoI.
EDITED: 21 May 2018 by VEGASGUITARS
Size: 94.6 KB, Downloaded: 27 times, Dimensions: 650x437px
On the road again!
My Moi French Site My Gallery
8876.63 In reply to 8876.61
Hi Neil, that has turned out great!
Nice Job!
Show messages:  1-4  5-24  25-44  45-64  65-78
