Opening OBJ and STLs in MOI
 1-2  3-22  23-29
8874.23 In reply to 8874.20
Just installed V4 on my Windows laptop and tested _STLimport script..
No problems it works...
Perhaps the download of the script files was not proper...
No more ideas why its not working for you... :-(
Ralf:)
looking for moments of inspiration...
8874.24 In reply to 8874.23
That's my suspicion as well. I just recently got a Windows 10 OS. I was able to download the .js file okay, but the .htm file just opened in another window, so I did a drag and drop onto my desktop and copied it from there. You wouldn't happen to have a zipped of it?
8874.25 In reply to 8874.24
Perhaps there is the problem..
Here is a zip
EDITED: 23 Mar 2018 by R2D3
8874.26 In reply to 8874.25
Thanks Ralf! That solved that problem. I'm getting some errors when I try it. See pics.
Any ideas? I tried the same 4 files in v3 and v4. Largest 5.8M and smallest 15KB. Some exported fro MoI and one from NX.
Thanks again for all your help!
8874.27 In reply to 8874.26
yes i saw this also for the first time when i testet in Windows "0 Triangles imported".
But than i opened an other stl and it works...
Must be something with different STLs - the one was from Moi3 and the good from V4 ...
Will have a look at it...
Ahhh, found it!
the bad was a binary STL this script only deals with Asci STLs!
Ralf:)
8874.28 In reply to 8874.27
used a online converter to asci and the bad file worked..
http://www.meshconvert.com
Ralf:)
8874.29 In reply to 8874.28
That was it! This works good!
Thanks again!
Michael T.
Show messages:  1-2  3-22  23-29
