Opening OBJ and STLs in MOI
 1-9  10-29
8874.10 In reply to 8874.8
Michael -
Speaking from my own experience, there have been times I've wanted to 3D print a free model from Thingiverse.com. Usually the only file format that is published is STL. Often I want to modify the model to fit my own requirements, so I end up creating my own model in MoI. I'm talking about models that are mechanical in nature rather than organic shapes. It's difficult because you have to somehow derive all the dimensions from a picture. If the STL can be brought into MoI it can at least serve as an accurate guide for drawing new curves and constructing the model with NURBS.
8874.11 In reply to 8874.10
Hi Ed, I'm kind of hesitant to focus on that type of reverse engineering workflow because STL triangulated data would need to be represented as a different category of object in MoI and that brings a lot of issues with people wondering why their imported STL data doesn't behave the same or interact with other regular objects drawn in MoI.
It will probably happen eventually.
Hi all,
what i don't quite understand with brining in an .stl model and the request for .stl import,
why don't people use not the free Meshlab and import there the .stl and save as .obj?
Meshlab is such a well known software in 3D circles.
8874.13 In reply to 8874.12
Hello Stefan!
@You : "...why don't people..."
Hmmm...good question :)
I totally agree with you!
8874.14 In reply to 8874.12
Thank you Stefan
You're welcome Rudy.
8874.16 In reply to 8874.5
I was not able to get the script to run. Am I doing something wrong?
8874.17 In reply to 8874.16
Hi MichaelT, it looks like you've got it set up ok there. What folder have you placed those 2 files "_STLimport.htm" and "_STLimport.js" into though?
8874.18 In reply to 8874.17
In here:
8874.19 In reply to 8874.18
Mmmh,
seems to be the right place for _STLimport.htm and _STLimport.js...
FOR MOI V4 BETA FEB-09-2018
What happens if you write _STLimport into the console?
8874.20 In reply to 8874.19
Tried that too. Nothing. No error, just nothing happens.
8874.21 In reply to 8874.20
i am on Mac and i never tested the script on Win...
But if there would be a problem on Windows at least you shoud get an error..
If you are using the latest V4beta Feb-09 Version it should work with this command folder at AppData..
What happens if you put the two files into the original commands folder?
Ralf:)
looking for moments of inspiration...
8874.22 In reply to 8874.21
Hi Ralf, I've tried that as well, but still nothing.
8874.23 In reply to 8874.20
Just installed V4 on my Windows laptop and tested _STLimport script..
No problems it works...
Perhaps the download of the script files was not proper...
No more ideas why its not working for you... :-(
Ralf:)
8874.24 In reply to 8874.23
That's my suspicion as well. I just recently got a Windows 10 OS. I was able to download the .js file okay, but the .htm file just opened in another window, so I did a drag and drop onto my desktop and copied it from there. You wouldn't happen to have a zipped of it?
8874.25 In reply to 8874.24
Perhaps there is the problem..
Here is a zip
EDITED: 23 Mar 2018 by R2D3
8874.26 In reply to 8874.25
Thanks Ralf! That solved that problem. I'm getting some errors when I try it. See pics.
Any ideas? I tried the same 4 files in v3 and v4. Largest 5.8M and smallest 15KB. Some exported fro MoI and one from NX.
Thanks again for all your help!
8874.27 In reply to 8874.26
yes i saw this also for the first time when i testet in Windows "0 Triangles imported".
But than i opened an other stl and it works...
Must be something with different STLs - the one was from Moi3 and the good from V4 ...
Will have a look at it...
Ahhh, found it!
the bad was a binary STL this script only deals with Asci STLs!
Ralf:)
8874.28 In reply to 8874.27
used a online converter to asci and the bad file worked..
http://www.meshconvert.com
Ralf:)
8874.29 In reply to 8874.28
That was it! This works good!
Thanks again!
Michael T.
Show messages:  1-9  10-29
