How to handle filets when changing a model later
All  1-4  5-7
8862.5 In reply to 8862.1
Hi Nico, yes I'd also recommend saving a version of your model before applying fillets, so you can go back to the pre-filleted state more easily later on.
8862.6
Thanks for the suggestions guys. I was able to fix my model. Sadly the script didn't work because the subsequent removal of faces broke some other faces (not the fault of the script - probably the geometry of my object). But I was able to delete the round edges and rebuild them with the help of lines and the planar feature. And I remembered to save a backup without filets this time :)
One other thing I learned. Sometimes when I create filets, they look broken because their size conflicts with the adjacent edges. If I go ahead and accept the "broken" filet, then I can still make it work by selecting the model and the broken filet and doing a boolean merge. Then I can delete the additional remains and have my filet.
8862.7 In reply to 8862.6
Hi Nicolinux!
Thanks for sharing your good idea !
Franz
Show messages: All  1-4  5-7
