How to handle filets when changing a model later
All  1-2  3-7
I've made several MoI models for my 3D Printer, and changes are always necessary.
I just keep all my construction lines / curves and rebuild the model. To me it's a lot faster than trying to fix it.
I also duplicate and keep intermediate versions of my work within the same file. For example, I keep a version prior to adding fillets, making holes, etc. That way I can make modifications easily.
8862.4 In reply to 8862.3
Hello Ed.
@You : "...I just keep all my construction lines / curves and rebuild the model. To me it's a lot faster than trying to fix it.
I totally agree with this point of view.
It's also my "style".
8862.5 In reply to 8862.1
Hi Nico, yes I'd also recommend saving a version of your model before applying fillets, so you can go back to the pre-filleted state more easily later on.
8862.6
Thanks for the suggestions guys. I was able to fix my model. Sadly the script didn't work because the subsequent removal of faces broke some other faces (not the fault of the script - probably the geometry of my object). But I was able to delete the round edges and rebuild them with the help of lines and the planar feature. And I remembered to save a backup without filets this time :)
One other thing I learned. Sometimes when I create filets, they look broken because their size conflicts with the adjacent edges. If I go ahead and accept the "broken" filet, then I can still make it work by selecting the model and the broken filet and doing a boolean merge. Then I can delete the additional remains and have my filet.
8862.7 In reply to 8862.6
Hi Nicolinux!
Thanks for sharing your good idea !
Franz
Show messages: All  1-2  3-7
