Saving a file with custom colors
All  1-2  3-7
8855.3 In reply to 8855.1
Hi Moujiik,
> I have a file with some custom colors, and i want to make a template of it.
> But when i reopen the file, all custom colors are gone. Is this normal?
It's normal if you used File > "Export" to generate the file instead of File > "Save As".
File > Export is for writing just the selected objects to the given file, and also only styles used by the selected objects will be present in the file as well.
File > "Save As" on the other hand will save everything including all styles. So this is the one you want to use for making a template file.
Please let me know if that wasn't the problem.
...setting up a 3DM file that contains the styles you want to have...
http://moi3d.com/3.0/docs/moi_command_reference11.htm#scenebrowser
8855.5 In reply to 8855.4
@Michael, it's not working. My custom colors are gone when i reopen the file.
@Benfarmer, what i am trying to save are the custom colors in style's edition panel.
Moujiik
Size: 312.6 KB, Downloaded: 61 times, Dimensions: 1216x752px
8855.6 In reply to 8855.5
Hi Moujiik, oh those custom colors - sorry I thought you meant your styles were not being saved.
I thought those would get saved automatically by Qt but I guess not. It looks like I should be able to save and load them to your moi.ini file so they will persist.
Thanks for reporting the problem.
8855.7 In reply to 8855.6
Message deleted by Moujiik
EDITED: 5 Mar 2018 by MOUJIIK
Show messages: All  1-2  3-7
