Marco (mkdm)'s very personal Moi V3 - A gift for all moiers :)
 1-14  15-34  35-54  55-61
Hello everyone.
I'm sorry if I use this place to reply a PM but, from what I remember, some times ago I disabled PM in my account options, but evidently I must have done some mistake.
Anyway...no problem. I'll check my options again to see if PM are actually disabled.
Meanwhile, I want to reply here to this PM.
Clearly, in fairness, I don't write here the name of the sender.
This was the original text :
"I've seen on some of your screen shots your command history window and I've looked over your scripts. A question for you, how has this helped you use MoI? Has helped you retracing steps when you've had to rebuild something or something else?
Not being parametric (and I'm ok with that) the biggest cycle stealer is when I have to change something and basically rebuild it."
Ok.
Well...I decided to build on my own, the little script/ui plugin dedicated to the Command History, mainly for one reason : speed of execution.
What I love most about Moi is its streamlined workflow, but for me it was still not enough :)
I wanted more.
I wanted an additional tool, that along with the wonderful short-cut keys embedded system, could give me also a visual help when it comes to launch scripts/commands.
For that reason I created my little plugin for Command History. Just in order to model at maximum speed!
I hope I have covered your question :)
Ciao!
8848.56 In reply to 8848.2
Wow! That's an amazing accomplishment Marco! Thanks for sharing your hard work and ideas!
8848.57 In reply to 8848.56
You're welcome! My pleasure :)
8848.58 In reply to 8848.4
So true Marco
8848.59 In reply to 8848.58
Yes!
8848.60 In reply to 8848.59
Hi Marco!
It is a particularly fine move of yours to make your work available to everyone. Unfortunately I hadn't found time yet, but I'm already looking forward when it's finally time for me to make the changes. Thank you in advance.
Franz
8848.61 In reply to 8848.60
I'm happy that you appreciate my "gift" :)
I really hope that you will not get problems in using my very personal config.
Unfortunately this year I have not enough free time to make it work also with V4...
We will see...
Have a nice day.
Show messages:  1-14  15-34  35-54  55-61
