Marco (mkdm)'s very personal Moi V3 - A gift for all moiers :)
 1-12  13-32  33-52  53-61
8848.33 In reply to 8848.32
Hello Rudl.
I'm sorry if I repeat again but :)
"Did you read the very first post of this tread ? ":) There you can find all the info you need :)
1) First : Read the title of this thread : "Marco (mkdm)'s very personal Moi V3 - A gift for all moiers :)"
This config works ONLY for V3. I said this into the first message of this post.
ASAP I will update it to work even with V4.
2) @You : "...i find all shortcuts from v3. Is there a way to seperate it...."
You have to ask Michael. I don't know how V3 and V4 manage their shortcuts, I'm sorry.
I have no problem because I use the same shortcuts on both versions.
3) @You : "... I haven´t found the nodeeditor,..."
Always from the first post of this thread :)
"I decided to not include into this package only the NodeEditor because each of us has for sure a very different version of N.E. :)"
Ciao!
Marco (mkdm)
8848.34
Ok Marco, thanks! : - )
8848.35 In reply to 8848.33
Hi Marco & Rudl,
For the Windows version v4 uses the same shortcuts as V3, from the same entry in the same moi.ini file so that's normal that they will be the same.
For the Mac version v4 uses a separate area of the moi.ini file ([Shortcut Keys Mac] instead of [Shortcut Keys]) than Mac v3 to avoid conflicts with Mac v3 which did not support using Alt+ separately from Cmd+ . It will be initialized though with the contents of the v3 [Shortcut Keys] section.
But any new shortcut keys you create in Mac v4 will be separate from Mac v3 and stored in the separate section in moi.ini .
8848.36
Why the same shortcuts, when the don´t function in V4. V4 should have it´s own shortcuts.
8848.37 In reply to 8848.36
Hi Rudl, what shortcuts do you have that don't function in V4 ?
8848.38 In reply to 8848.35
Hello Michael.
@You : "...For the Windows version v4 uses the same shortcuts as V3, from the same entry in the same moi.ini file so that's normal that they will be the same..."
Thanks for the info :)
About Mac side, because I have Windows 10 Pro and I don't know if my personal config of V3 can work well also on Mac Os,
I think it's better that I put more emphasis on the first post of this thread that this config is tested and works well only on Windows machines.
I've already did so when I published the post for the very first time, but maybe it's better to write this annotation with a bigger character :)
A couple of minutes and I'm going to update.
Ciao!
Hello everyone!
After helping some of you during the config of my special version of Moi V3 I realized that I had to renew the instructions and manual :)
So, some minutes ago I renewed the very first post of this thread (http://moi3d.com/forum/index.php?webtag=MOI&msg=8848.2)
Please, read always the very first post in order to get all the info you need to setup this special version of Moi V3.
I will always keep up to date that post when I change something.
Ciao!
8848.40
Hi Marco,
I just came by MoI3D's forum this morning and - by inspiration - clicked on this forum thread describing your customized MoI setup ... I decided to watch your short introductory video (intentionally without sound I assume?) and would like to say that it looks awesome what you have done ;-) ... A major expansion of MoI3D's IMHO already fine UI ... Many thanks for sharing! ...
Cheers,
Jesper
8848.41
Marco, once more.
Thank you very much for your gift and your patience for me.
Rudl
8848.42 In reply to 8848.40
Hello EVALON.
@You : "...(intentionally without sound I assume?) ..."
Yes, intentionally. English in not my native language so I prefer to record without voice ;)
Thank you very much for your kind words. I'm glad that you like my setup.
ASAP I'm going to make a little update in order to make it work also with Moi V4 and not only on V3 as is actually.
Have a nice day.
Ciao!
8848.43 In reply to 8848.41
Hello Rudl.
You're welcome! No problem. It's fine that now all works for you (I assume...)
Remember that for any update or help, you can always take a look at the very first post of this thread.
There you can always find all the things you need to use my setup.
If any of you notice some kind of mistake please let me know and ASAP I will update the first post.
Ciao!
8848.44
And... something other, not closely related to the thread's main theme but it has to be asked (it is a problem I have met before seeing the thread here in fact): The 'scale array plugin' is not working. Whenever I click the related (linked to it) key, there opens the plugin's settings window but it is flickering and not staying there when leaving the key. Of course it is not possible to work with it in such a way. What may be going on? Any idea?
8848.45 In reply to 8848.44
Hi Dimitri.
Strange thing..it's the very first time I read about this problem.
Please, post some screenshot and/or even better a video screen capture.
Also tell me your config.
I remind you that this special configuration of Moi is only for V3 and was tested ONLY on Windows 10 Pro.
Ciao!
8848.46
Marco the problem does not permit taking a screenshot, because as I said before the dialogue window appears only as far as I keep pressed the related key in the keyboard (say 'J' in this case). And even then (when keeping pressed the key) the dialogue box flickers. It happens only with the 'scale array'. It is strange indeed. I am using the present, v.3, of Moi (in Windows Seven). Most probably it is a problem that this particular plugin has. Did you check it in the v.3? Is it working there?
8848.47 In reply to 8848.46
Hi Dimitri.
@You : "...Most probably it is a problem that this particular plugin has. Did you check it in the v.3? Is it working there?..."
I'm sorry Dimitri that you're having this strange issue but as I have said before I never heard about that, and I don't think that is related to this special config of Moi because I've exactly this config and I have no problem at all with the Max's "ScaleArray" plugin.
But you have written that you have Windows 7...
As I said in the previous post and in the very first post of this thread, this special config of Moi V3 was tested only on Windows 10 Pro 64 Bit, because I have and use only that OS.
Anyway if your problem is related to the "SacleArray" you should ask to Max, the author of that plugin, using the forum thread named "ping - Max Smirnov".
I'm sorry but I can't help you in other ways :)
Ciao.
8848.48
Ok Marco, I will ask to Max. Thanks a lot for your so dedicated answers! : - )
8848.49 In reply to 8848.44
Hi Dimitri, re: ScaleArray, what you describe will happen if you have not prepared the input that ScaleArray expects which is that a point object should be included in the selected objects to be used as the origin point for the scale.
More info here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7008.1
8848.50
Now it is ok! Thanks for the quick reply Michael! : - )
8848.51 In reply to 8848.2
Hi Marco,
I tried installing your setup but there's something wrong.
When I open MoI I get this error message:
http://prntscr.com/io1oh2
After I hit OK it opens like this, the standard MoI setup:
http://prntscr.com/io1ox1
I was hoping you could help me out.
pine
8848.52 In reply to 8848.51
Hello PINE_X2.
I'm sorry that things don't work for you, but it's the first time I read about this error.
Let me ask you something :
1) Did you follow exactly ALL the steps that I've written in the very first post of this thread ?
2) This special config of Moi in dedicated ONLY to Moi V3 not for V2 or V4
3) This special config were tested only on Windows 10 Pro. I don't know how it works, if it works, with different OS
Anyway, it seems that the problem is with this javascript line code var customuidir = moi.filesystem.getUIDir()+"\\customui"
but I don't know why this instruction shouldn't work.
I never had this problem before.
@You : "...After I hit OK it opens like this, the standard MoI setup:.."
What you see is NOT the standard Moi setup.
Is just "my" special config. You're missing only the icons relative to Max's Custom UI, related to the error you're getting.
Ciao :)
Show messages:  1-12  13-32  33-52  53-61
